408 Stroker Questions and Opinions Purttty Please! #67200
06/04/08 03:27 AM
06/04/08 03:27 AM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
Ok,
I made the recent budget build 360 (425 hp) thread not to long ago. Well I was able to find a 2001 Magnum motor that was only $200 dollars. Once we took it apart we noticed that the heads were cracked . I did some searching on e-bag and come across a company that rebuids Magnum heads and has been in business for 30+ years. Here is there link: http://cgi.ebay.com/ebaymotors/ws/eBayIS...565164&rd=1
The price is $175 per head and they accept cracked heads as cores! I have a few questions would these be adequate heads for a low buck, but fun street stroker in an A-body? When the money is right I will either buy some EQ heads or Eddies, but will these hold me over till then?
The block has to be bored .030 over and I'm planning on going with the Scat Stroker kit.
I'm leaning towards a single plan Edelbrock intake with a 750 3310 Holley carb.
As far as the camshaft goes, that's where I'm totally clueless. I'm sure I'll be using Comp. I don't really mind an aggressive cam so some suggestions would be greatly appreciated.
My ultimate goal would be in the 425hp range and 450+ tq. If it makes more, then even better.
Instead of going through my engine shop I'm going to come up with a parts list and source them all on my own to save the extra cash.
I'm sure some of my information that I supplied is very vague, but when it comes to engines, I know absolutely nothing.
I want to be able to run in the mid 12's for sure in a 3300 pound A-body that has 4.10 gears.
So if anyone can shed some light on terrible questions (best I can do ). I will jump through hoops and cut back flips!
Thanks again Moparts!
Regards,
Charles
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67201
06/04/08 07:44 AM
06/04/08 07:44 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Take a look at the specs of MP's 402/408 stroker crate motor. http://store.summitracing.com/partdetail...mp;autoview=sku
These engines are awesome. My grandfather has one in his Demon. It runs on 87 octane and has pushed the car to a best of 12.10. I think a build up similar to the 402 (cam, heads, stroke, and intake wise) with 10:1 compression would be great and yield high 11's easily.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: bigsbigelow] #67202
06/04/08 08:16 AM
06/04/08 08:16 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, you're going to need to do some port clean up on stock magnums to hit 425+ HP, nothing major, Dulcich had an article in an '05 mopar muscle with some minor bowl, valve job, and port pinch work that added ~25CFM to flow on some maggies, which would yield them to support 450-460hp.
one thing to remember with the reman heads--you'll still need to buy new springs/retainers for any type of performance cam, so that'll add more cost, whereas CME engines sells new enginequest heads w/ chevy +.1" long valves, 5 angle valve job, and springs that'll handle a hydraulic roller up to ~.550" lift for under $900/pr. if you're into some reman heads for $350, and have to spend another $200-300 for springs & retainers (hard to find a low cost spring/retainer solution for mag heads, unless you can find a few 2.2L/2.5L mopars in junkyards to yoink the retainers off of), it might be better just to go new/chev 11/32" stem valves.
what kind of R's do you want to turn? maggies have a small cross section, and they'll make their best power on a 408 on the idle-5500 RPM range, so I'd cam accordingly (probably a roller cam similar to the crate motor cam, but with a little wider LSA, personally). you might want to save the $$ and just use some 0 deck KB107's and the stock stroke.
2017 Grand Cherokee Overland
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: patrick] #67203
06/04/08 03:43 PM
06/04/08 03:43 PM
Houma, Louisiana
Houma, Louisiana
Yeh I figured those reman heads would def. need some work and the additional parts needed, it might be better to just go with the EQ heads. Where is the cheapest place to buy them? And do they require cores? If not I've got two boat anchors.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67204
06/04/08 04:00 PM
06/04/08 04:00 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Doubt you would need 4:10 gears. 3:55's or maybe 3:91's would be fine. These motors make an abundance of torque so using a streetable gearset like a 3:55 still works good.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: Neil] #67205
06/04/08 05:35 PM
06/04/08 05:35 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
you might want to save the $$ and just use some 0 deck KB107's and the stock stroke. YEPPERS
Yep, I got the specs for a real world 425 hp 360 with a comp mag 280 (id have to look) hydro cam, simple bowl work j heads, single plain, 750 avenger. 1 5/8 headers.
Strokers love duration, the biggest mistake ive been seeing make is people not keeping there dynamic comp in line with there cam. Same cam in a 360 wont cut it in a stroker.
540 solid in same motor made a bit more hp but 10 pounds less peak torque then the hydro.
If your doing a simple stroker 525 is an easy figure to shoot for with a bit better heads.
But as mentioned some zero decks and a good stock crank and rods balanced and your in...
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: quick77rt ] #67206
06/04/08 06:14 PM
06/04/08 06:14 PM
Czech Republic, Central Europe
BobAsh Offline
BobAsh  Offline
Gettin' old iron accross the pond...
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: BobAsh] #67207
06/04/08 09:06 PM
06/04/08 09:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I am guessing you called Best machine? Chuck just build a 408 for a friend of mine in Europe, it was just a junk yard 360, plain jane mid 70's 915 J heads with mild port work and a good valve job, HYD. Cam, pump gas compression, and had a customer supplied intake (EB Performer which certainly choked it real well) but all else was just a basic 360 stroker build. He just dynoed it and it came in at 435 HP/465LB Torque. Not bad for an off the shelf-no trick parts or machine work build. If it were me I'd have him start from scratch and build you an all new long block and toss your other engine under the work bench for someday.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: ScottSmith_Harms] #67208
06/04/08 09:14 PM
06/04/08 09:14 PM
BobAsh Offline
BobAsh  Offline
What was the cost?
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: BobAsh] #67209
06/04/08 09:21 PM
06/04/08 09:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I didn't ask, give Chuck a call and he can give you a quote. I've found his work to be reasonable/competitive.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: ScottSmith_Harms] #67210
06/04/08 09:26 PM
06/04/08 09:26 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A budget stroker smallblock would probably start in the $4,500ish zone if you were to assemble it yourself.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: Neil] #67211
06/05/08 01:34 AM
06/05/08 01:34 AM
Houma, Louisiana
Houma, Louisiana
The price is really nice on the 408 Blue Print Engines and the warranty is a very nice addtion. I've just heard mixed reviews regarding these engines. Basically all I'd need to do is buy a carb, some headers and call it a day. $4200 doesn't sound so bad.
I wish I just knew more about the company and this particular motor before dropping that kind of scratch.
If there are a few owners or people that know someone who has one on the site that has a substantial amount of information on these engines could you guys/gals chime in? For instance do they only come in black? I'd def. like to have mine orange.
Luckily if I do happen to go this route I only spent a little over $200 for the Magnum motor. Everything on the motor besides the heads are good to go. Is there a market on any of these parts (Crank, bare block etc) so I can at least recoupe my money?
Gosh I love this hobby, but when it comes to certain things I crawfish (means change my mind in cajun country) on what I'm going to do. I'm just a college student with limited funds, trying to build a very nice engine without having to visit the plasma facility weekly.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67212
06/05/08 07:44 AM
06/05/08 07:44 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
contact these guys for EQ heads:
http://www.cmengines.com/
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67213
06/05/08 07:48 AM
06/05/08 07:48 AM
NY usa
540challenger Offline
NY usa
I have purchased the blue crate engine what would you like to now???
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: 540challenger] #67214
06/05/08 06:09 PM
06/05/08 06:09 PM
Houma, Louisiana
Houma, Louisiana
Was yours the 408 stroker? And if so, are you pleased with it? Did you get the base engine or the turnkey engine? All info will be helpful.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67215
06/05/08 11:00 PM
06/05/08 11:00 PM
NY usa
NY usa
i have the 408 base, I very pleased with the einge about 3500 miles on it now.
2 problems i had with it was they didn't index the intermediate shaft correctly but no big deal.
Then the dipstick hit the crank but that might of been my fault b/c i removed the tub and stick and bent it a little when i reinstalled it.
For the money imo you get get alot better parts then the turn key offers.
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: 540challenger] #67216
06/05/08 11:24 PM
06/05/08 11:24 PM
Houma, Louisiana
Houma, Louisiana
If I may ask, what did the engine cost and was there a core charge? What did you install the engine in? Thanks
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: twister360] #67217
06/06/08 12:32 AM
06/06/08 12:32 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have the turn key or dressed model. Installed in 68 barracuda fastback, auto, The warranty was what made me lean towards it. With all the wiped cam lobes out there I liked that they run it for 20 min. on a dyno before they ship it. I'm pretty sure you could build one cheaper, but I'm happy with mine. $7700.00 delivered no core charge, Mine put out more than the advertised hp/tq figures.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 408 Stroker Questions and Opinions Purttty Please! [Re: FurryStump] #67218
06/06/08 03:15 PM
06/06/08 03:15 PM
NY usa
NY usa
Mine was around 3800-3900 shipped.
