Eating Tranny Mounts Opinions needed. #670676
04/15/10 03:26 PM
04/15/10 03:26 PM
IMGTX Offline OP
IMGTX  Offline OP
I am on my third or fouth tranny mount in as many years. There is no driveline vibration and maybe it's just cheap crappy mounts.
1. Is there a company that sells better quality mounts, preferably made in the USA?
2. How much vibration am I going to pick up from a poly mount. This is a daily driver traveling car so I do like the quiet smooth ride.
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670677
04/15/10 03:34 PM
04/15/10 03:34 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
What's the vehicle? Poly Bushings (http://www.polybushings.com/) makes some great parts but limited to just a few specific vehicles at this time.
Re: Eating Tranny Mounts Opinions needed. [Re: Chilort] #670678
04/15/10 05:38 PM
04/15/10 05:38 PM
IMGTX Offline OP
IMGTX  Offline OP
oops
74 Satellite
Do the Poly's add noticable vibrations?
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670679
04/15/10 07:38 PM
04/15/10 07:38 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
oops
74 Satellite
74 B body Is it a small block car that has a big block in it now?
Re: Eating Tranny Mounts Opinions needed. [Re: rrunner] #670680
04/15/10 08:00 PM
04/15/10 08:00 PM
IMGTX Offline OP
IMGTX  Offline OP
Nope just a bone stock 318 2bbl.
Re: Eating Tranny Mounts Opinions needed. [Re: rrunner] #670681
04/15/10 08:02 PM
04/15/10 08:02 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Schumaker makes a rear mount that is supposed to be stronger. I have not used one as I have no troubles with my rear mount.
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670682
04/15/10 08:03 PM
04/15/10 08:03 PM
Dirk Offline
Dirk  Offline
Have you checked the motor mounts? If those aren't intact they will stress the tranny mount.
Re: Eating Tranny Mounts Opinions needed. [Re: Dirk] #670683
04/15/10 08:08 PM
04/15/10 08:08 PM
IMGTX Offline OP
IMGTX  Offline OP
Yep the motor mounts are in good shape.
Are the Schumaker mounts stiff?
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670684
04/15/10 08:17 PM
04/15/10 08:17 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Do you have a leak that is getting the mount wet?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670685
04/15/10 08:32 PM
04/15/10 08:32 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I'd say that you are correct about you problem being cheap mounts. It seems like the parts store mounts are junk in no time. I think that same mount was used at least until the late '80's when the Fifth Avenue was discontinued so it may be available at the dealer or a poly mount insert, as mentioned above, is a good option too.
Re: Eating Tranny Mounts Opinions needed. [Re: WyleECoyote] #670686
04/15/10 08:32 PM
04/15/10 08:32 PM
IMGTX Offline OP
IMGTX  Offline OP
Nothing abnormal.
I'm thinking it is just cheap chinese rubber.
I figure I will try to get a good mount and be done with it.
Re: Eating Tranny Mounts Opinions needed. [Re: IMGTX] #670687
04/15/10 09:01 PM
04/15/10 09:01 PM
New Mexico, USA
attaboy Offline
attaboy  Offline
New Mexico, USA
I'd say it's the cheap mount material(s). I just replaced my OEM one with one from NAPA. The steel is a thinner gage and the horizontal strengthing bracket that is welded to the mount on the OEM one is missing from NAPA's. The rubber only partially fills the mount cavity and to top it all off the, the darn thing is made in India! I think that the NAPA part is somehow related to No_Politics's health care plan.
I wrote an email to the maker but ofcourse, I've not gotten a reply. Next time I'm going with the poly type widly sold on ebay.
attaboy
Re: Eating Tranny Mounts Opinions needed. [Re: attaboy] #670688
04/15/10 09:44 PM
04/15/10 09:44 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
not sure how much vibes the poly will transfer. my dakota has solid engine mounts with a poly trans mount on the TKO, and I have a vibration I'm trying to sort out. I'm hopeful it was the drive shaft, when I had it built, I had them balance it at around 6,000 rpm, but was getting a vibration at around 60mph, which was around 3,100 rpms. had the shaft re-balanced, and they did add some weight to it. the new balance job was done at 2700 rpm. I'm hopeful that this fixed my vibes. if not, I might look at tossing my poly mount and seeing what a rubberone will do.
however, the 'experts' will tell you that the mount will NOT cause the vibration...it just transmits it to the frame so you can feel it--so if you go from rubber to poly and pick up a vibe, that means something else is wrong, and the vibe was being absorbed by the rubber in the mount...could be why it falls apart so quickly too
**Photobucket sucks**
Re: Eating Tranny Mounts Opinions needed. [Re: 70Cuda383] #670689
04/15/10 11:09 PM
04/15/10 11:09 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Yes, poly does transfer more vibration.
I broke a stud off a Schumacher engine mount before I even got to the point where I was ready to apply real torque. I went to AutoZone (gasp) and bought an engine mount and it is fine.
383man [Re: Dirk] #670690
04/15/10 11:36 PM
04/15/10 11:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Bingo ! This happened to me some years back on my 340 Dart. The motor mounts were ok but the bolts that held the motor mount brackets to the block were loose. My car would actually break the trans mount. Ron
Re: 383man [Re: 383man] #670691
04/16/10 03:53 AM
04/16/10 03:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I used to go through tranny mounts on my 71 RR like they were candy..
switched to a Energy Suspension 5-1101G and never looked back..
I am truckless..
Re: 383man [Re: 340SHORTY] #670692
04/16/10 10:00 AM
04/16/10 10:00 AM
IMGTX Offline OP
IMGTX  Offline OP
How bad was the vibration increase?
Re: 383man [Re: IMGTX] #670693
04/16/10 11:01 AM
04/16/10 11:01 AM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
I don't run poly on my '68 truck because no one makes poly for it (not actually 100% true. Imperial Services makes the trans isolator but they haven't been able to figure out how to keep the metal from delaminating from the poly but its a quality issue with their parts and not poly in general).
I do run poly in my '86 Daytona Turbo Z and it is actually annoying. I only switched one of the three isolators and I won't be doing the other two. But the 2.2L engine was always known for vibrating like crazy. I don't honestly know what it would be like on a V8.
I hope to find out soon though as there's a chance one of the Poly locking isolators made by Poly Bushings will work as an engine mount for my truck. Right now I have the engine strapped down with a chain. It is the only way I can keep from breaking engine and trans isolator.s
