Re: Eating Tranny Mounts Opinions needed.
[Re: IMGTX]
#670679
04/15/10 07:38 PM
04/15/10 07:38 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
oops
74 Satellite
Do the Poly's add noticable vibrations?
74 B body Is it a small block car that has a big block in it now?
[Re: IMGTX]
#670684
04/15/10 08:17 PM
04/15/10 08:17 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Do you have a leak that is getting the mount wet?
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: IMGTX]
#670685
04/15/10 08:32 PM
04/15/10 08:32 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I am on my third or fouth tranny mount in as many years. There is no driveline vibration and maybe it's just cheap crappy mounts.
1. Is there a company that sells better quality mounts, preferably made in the USA?
2. How much vibration am I going to pick up from a poly mount. This is a daily driver traveling car so I do like the quiet smooth ride.
I'd say that you are correct about you problem being cheap mounts. It seems like the parts store mounts are junk in no time. I think that same mount was used at least until the late '80's when the Fifth Avenue was discontinued so it may be available at the dealer or a poly mount insert, as mentioned above, is a good option too.
[Re: attaboy]
#670688
04/15/10 09:44 PM
04/15/10 09:44 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
not sure how much vibes the poly will transfer. my dakota has solid engine mounts with a poly trans mount on the TKO, and I have a vibration I'm trying to sort out. I'm hopeful it was the drive shaft, when I had it built, I had them balance it at around 6,000 rpm, but was getting a vibration at around 60mph, which was around 3,100 rpms. had the shaft re-balanced, and they did add some weight to it. the new balance job was done at 2700 rpm. I'm hopeful that this fixed my vibes. if not, I might look at tossing my poly mount and seeing what a rubberone will do.
however, the 'experts' will tell you that the mount will NOT cause the vibration...it just transmits it to the frame so you can feel it--so if you go from rubber to poly and pick up a vibe, that means something else is wrong, and the vibe was being absorbed by the rubber in the mount...could be why it falls apart so quickly too
**Photobucket sucks**
383man
[Re: Dirk]
#670690
04/15/10 11:36 PM
04/15/10 11:36 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Have you checked the motor mounts? If those aren't intact they will stress the tranny mount.
Bingo ! This happened to me some years back on my 340 Dart. The motor mounts were ok but the bolts that held the motor mount brackets to the block were loose. My car would actually break the trans mount. Ron
Re: 383man
[Re: 383man]
#670691
04/16/10 03:53 AM
04/16/10 03:53 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I used to go through tranny mounts on my 71 RR like they were candy.. switched to a Energy Suspension 5-1101G and never looked back..
I am truckless..
