1.5 vs 1.6 Rocker Ratio #669360
04/13/10 10:52 PM
04/13/10 10:52 PM
Amarillo, Texas
red70duster Offline OP
Amarillo, Texas
Has anyone tried using 1.6 ratio rocker arms with Edelbrock heads? I thought about switching to 1.6's to increase the lift on my 555 lift Isky cam but I am wondering if I will run into interference problems with the pushrods and heads?
GM
Re: 1.5 vs 1.6 Rocker Ratio [Re: red70duster] #669361
04/14/10 12:23 AM
04/14/10 12:23 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
got 1.6 T&D's on my SB eddys no clearance issues
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 1.5 vs 1.6 Rocker Ratio [Re: red70duster] #669362
04/14/10 01:26 AM
04/14/10 01:26 AM
Cab_Burge Online work
Cab_Burge  Online Work
I put a new set (two years ago now) of Harland Sharp 1.6 on my Eddy RPM BB heads, I had to grind on one (#6 intake port) head and ended up putting a hole in the side of the #6 intake port CNC ported heads I had it welded up and it is fine now my Harland Sharps check at the retainers to actually have 1.64 ratio instead of 1.60 I have another set of Harland Sharp 1.5 (twenty years old, not much use on them )that are on a unported set of Eddy RPM and they fit fine, no mods required I also have a set of Indy SR heads that I put a set of T&D 1.65 rockers on and they needed grinding also, no holes on them IHTHs. BTW, the change of rockers did help that motor, The old set of CAT rockers checked at the retainers to be 1.46 ratio instead of 1.60
Re: 1.5 vs 1.6 Rocker Ratio [Re: Cab_Burge] #669363
04/14/10 09:49 AM
04/14/10 09:49 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
IF your using 3/8's push rods I would think you would have a clearnce issue.
I did.
Re: 1.5 vs 1.6 Rocker Ratio [Re: WILD BILL] #669364
04/14/10 10:55 AM
04/14/10 10:55 AM
Amarillo, Texas
Amarillo, Texas
Thanks for the replys. I'm currently running Harland Sharp 1.5 with the Edelbrocks and no issues. I thought trying a set of 1.6's like the ones for sale by a member here would be a good way to see if the car would like more lift. Since the heads have not been ported I have my doubts. My pushrods are 5/16 Comp Cams.
GM
Re: 1.5 vs 1.6 Rocker Ratio [Re: red70duster] #669365
04/15/10 12:54 PM
04/15/10 12:54 PM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
I tried both Crane 1.5 and 1.6 with Big block RPM and had no clearance issues. Did not notice a big increase in power either though, so I now have Harland 1.5's.
Re: 1.5 vs 1.6 Rocker Ratio [Re: bobdog106] #669366
04/15/10 05:53 PM
04/15/10 05:53 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I thought that an increase in lift will increase torque, not horse power?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 1.5 vs 1.6 Rocker Ratio [Re: 68LAR] #669367
04/16/10 09:26 AM
04/16/10 09:26 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
That depends on where the head flows best.
