Re: 727 trans oil -What are you using? [Re: DavidDean] #668381
04/13/10 12:23 AM
04/13/10 12:23 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
dexron/mercon 5 in mine.
I've seen the fluid issue debated many times. Many testimonials for mercon derivatives, and type F fluids.
Personally, I think that over all these years of torqueflight use, by many different party's, one thing has been proven.... That A 727 doesn't care what fluid you use AS LONG as it was built right
Re: 727 trans oil -What are you using? [Re: dave571] #668382
04/13/10 12:54 AM
04/13/10 12:54 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Cheapo (beacause it leaks ) type F as well.
Re: 727 trans oil -What are you using? [Re: MrFoFody] #668383
04/13/10 09:16 AM
04/13/10 09:16 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
autozone/advance auto type F. been running it since rebuilt in 2003 and still going strong.
Re: 727 trans oil -What are you using? [Re: RonP] #668384
04/13/10 11:30 PM
04/13/10 11:30 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
727 6 clutches, billet steel drum, dex3 as per trans builders suggestion. sometimes doing the rounds the trans gets hot but you'd never guess with smelling my fluid. i did try type F but trans man said no so dex 3 it is.
Re: 727 trans oil -What are you using? [Re: rebel] #668385
04/13/10 11:54 PM
04/13/10 11:54 PM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Duraguard universal hydraulic fluid !!!!!
its thicker werks grate for high HP.
tranny been bulit proof for 4 years till now the T brake solenoid quit.
Post deleted by Defbob [Re: RockChip] #668386
04/14/10 12:11 AM
04/14/10 12:11 AM
Re: 727 trans oil -What are you using? #668387
04/14/10 12:15 AM
04/14/10 12:15 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Yup but it also makes converter slip less!!!
Re: 727 trans oil -What are you using? [Re: RockChip] #668388
04/14/10 01:56 AM
04/14/10 01:56 AM
Type F since 1973 when we ran a Art Carr trans,Marv ripes at A-1 trans says type F in 727, Dave Smitth at Pro Trans says type F with no trans brake. Mopar engineers in the old drag racing seminars said type F also
Re: 727 trans oil -What are you using? [Re: Cab_Burge] #668389
04/14/10 08:02 AM
04/14/10 08:02 AM
Lehigh Acres, Florida
rickstershemi Offline
Nothing but cheapo type-F
Rickster
