Re: 727 trans oil -What are you using?
[Re: 440Jim]
#668364
04/12/10 07:23 PM
04/12/10 07:23 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used to use Type F. Now running AmsOil.
Kinda wondering why as I haven't seen much diference.
Might go back to type F ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: TomsCharger70]
#668365
04/12/10 07:38 PM
04/12/10 07:38 PM
Thumperdart
State of confusion
Type F in my 727 per request.
[Re: WILD BILL]
#668367
04/12/10 08:05 PM
04/12/10 08:05 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Amsoil mimmicks type F. It's the synthetic fluid I recommend for my builds. If not, name brand type F.
[Re: Leigh]
#668369
04/12/10 08:12 PM
04/12/10 08:12 PM
Posts: 16,931 NC
440Jim
NC
For a mostly stock torqueflite, I agree type F has its use. But my trans has 5 frictions in the front drum, and 165 psi line pressure. It doesn't need the extra friction of the type F, and I believe (hope?) Dexron will lubricate better.
And if you only change the fluid once a year (or less), I agree a name brand fluid would be my choice over a store brand.
My last fluid change, Castrol ATF was on sale almost as cheap as the store brand, so I bought the Castrol. Even though normally I use the cheap stuff. I put 7 qts in my setup when I change the fluid and filter every 30-40 passes, and my trans looks good inside (several inspections over the years). So, I am not spending $8-12/qt on fancy ATF. Have you seen the price of Royal Purple ATF?
[Re: MR_P_BODY]
#668373
04/12/10 08:29 PM
04/12/10 08:29 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
John Force's favorite here....Castrol GTX Type F
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
