727 trans oil -What are you using? #668361
04/12/10 07:04 PM
04/12/10 07:04 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
As the topic states -What 727 transmission oil are you guys running???
/Tom
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668362
04/12/10 07:14 PM
04/12/10 07:14 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Dexron III this time around.. use to use type3 mopar but that has gone away..try type fa last time but realy did;t like it.
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668363
04/12/10 07:16 PM
04/12/10 07:16 PM
NC
440Jim Offline
440Jim  Offline
NC
Just some cheap Dexron. I change it every 30-40 passes since I have an aluminum front drum.
Re: 727 trans oil -What are you using? [Re: 440Jim] #668364
04/12/10 07:23 PM
04/12/10 07:23 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used to use Type F. Now running AmsOil.
Kinda wondering why as I haven't seen much diference.
Might go back to type F
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668365
04/12/10 07:38 PM
04/12/10 07:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Type F in my 727 per request.
Re: 727 trans oil -What are you using? [Re: WILD BILL] #668366
04/12/10 07:41 PM
04/12/10 07:41 PM
Stockholm, Sweden
Stockholm, Sweden
OK, seems most just use the more or less over the counter everyday trans oils...
I have been running Type F in the trans. Just had it rebuilt because, well long story short, the low/rew drum split in two..
Guess Ill continue to run Type F oil in it..
/Tom
Re: 727 trans oil -What are you using? [Re: WILD BILL] #668367
04/12/10 08:05 PM
04/12/10 08:05 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Amsoil mimmicks type F. It's the synthetic fluid I recommend for my builds. If not, name brand type F.
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668368
04/12/10 08:07 PM
04/12/10 08:07 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Type F here.
Nautilus Racing-
Re: 727 trans oil -What are you using? [Re: Leigh] #668369
04/12/10 08:12 PM
04/12/10 08:12 PM
NC
440Jim Offline
440Jim  Offline
NC
For a mostly stock torqueflite, I agree type F has its use. But my trans has 5 frictions in the front drum, and 165 psi line pressure. It doesn't need the extra friction of the type F, and I believe (hope?) Dexron will lubricate better.
And if you only change the fluid once a year (or less), I agree a name brand fluid would be my choice over a store brand.
My last fluid change, Castrol ATF was on sale almost as cheap as the store brand, so I bought the Castrol. Even though normally I use the cheap stuff. I put 7 qts in my setup when I change the fluid and filter every 30-40 passes, and my trans looks good inside (several inspections over the years). So, I am not spending $8-12/qt on fancy ATF. Have you seen the price of Royal Purple ATF?
Re: 727 trans oil -What are you using? [Re: 440Jim] #668370
04/12/10 08:25 PM
04/12/10 08:25 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
If there is a lube issue, hp level dictates roller. I am still using type f in my 5 clutch unit. I don't see any issues with more coefficient. Most 727's I see have front clutch heat check issues, which indicates lack thereof, or clearance issues. I have gone to clearances that were verboten 20 years ago.
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668371
04/12/10 08:27 PM
04/12/10 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cheapo type F here
Re: 727 trans oil -What are you using? [Re: Leigh] #668372
04/12/10 08:29 PM
04/12/10 08:29 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree many 727 builds have front clutch issues. But my setup doesn't (and it sounds like yours doesn't either). I like the 5 friction setup (high torque, race, application).
What front clutch clearance are you running? I have settled on 0.075", but have run down to 0.060".
Re: 727 trans oil -What are you using? [Re: MR_P_BODY] #668373
04/12/10 08:29 PM
04/12/10 08:29 PM
Jarrettsville, MD
tywebb2 Offline
super gas
tywebb2  Offline
super gas
Jarrettsville, MD
John Force's favorite here....Castrol GTX Type F
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: 727 trans oil -What are you using? [Re: tywebb2] #668374
04/12/10 08:38 PM
04/12/10 08:38 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
one more with TF, here.
Re: 727 trans oil -What are you using? [Re: TomsCharger70] #668375
04/12/10 08:39 PM
04/12/10 08:39 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Type F
Re: 727 trans oil -What are you using? [Re: 440Jim] #668376
04/12/10 08:46 PM
04/12/10 08:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Coming from the "keep it at .050" days, it was hard (25 years of .0125 per disc) to start seeing .075-.080 It makes snap ring/oversize steel selection a breeze. I'm anal, so it would sometimes take me a couple of hours, and sometimes machine shop expense, to arrive at .050.
Re: 727 trans oil -What are you using? [Re: Leigh] #668377
04/12/10 09:55 PM
04/12/10 09:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Dex 3,prefer name brand
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 trans oil -What are you using? [Re: hemi-itis] #668378
04/12/10 10:08 PM
04/12/10 10:08 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Type F here too. I also subsitute 1 qt of 30w for a qt of trans fluid. If it ain't broke, don't be trying fix it.
Brian
Re: 727 trans oil -What are you using? [Re: '72CudaRacer] #668379
04/12/10 10:14 PM
04/12/10 10:14 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run a 904 and Type F
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 727 trans oil -What are you using? [Re: 11secdart] #668380
04/12/10 10:21 PM
04/12/10 10:21 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
904 Mobil 1 ATF w/Lucas additive. About 20* cooler w/ y trans brake.
