Re: Can a 904/727 Trans be flat towed?
[Re: 397STROKER]
#667772
04/13/10 03:20 PM
04/13/10 03:20 PM
Posts: 15,493 the boonies
aarcuda
the boonies
probably didnt hurt anything cause the fluid level was high enough to lube the output shaft.
whats the first thing that happens when you pull the driveshaft??? tranny fluid runs out the tranny
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: 397STROKER]
#667773
04/13/10 03:27 PM
04/13/10 03:27 PM
Posts: 2,826 NY usa
540challenger
NY usa
I knew some people that flat towed their race cars many years ago and they used tow hubs. They were not all mopars either. They didn't want to over heat the rears or the trans.
Tow hubs are great but i haven'1 been able to find any. Do they still make them??
[Re: aarcuda]
#667776
04/13/10 08:00 PM
04/13/10 08:00 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
No - when using the set up discribed above nothing in the transmission was turning. The wheels were free wheeling somewhat like having it on a dolly.
[Re: aarcuda]
#667777
04/13/10 11:02 PM
04/13/10 11:02 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
You don't need to compltely remove the drive shaft, just undo the u-bolts on the rear u-joint, remove the u-joint from the yoke, wrap some tape around the u-joint to keep the cups on and tie up the drive shaft away from the yoke and to keep it from falling out going down the road. Takes 5-10 min.
[Re: Dean_Kuzluzski]
#667779
04/14/10 12:32 PM
04/14/10 12:32 PM
MoparforLife
Upper Midwest
The low/rev drum to rr support contact surface area won't get lubed w/o pressurized oiling. Splash oiling is shielded by the valvebody. No bushing there either, that's why it gets "rollerized" in serious race applications.
The quotation above was referring to the tub towing and with that method even with the drive shaft hooked up it is not turning so there is no danger from injuring the internals of the transmission.
#667781
04/14/10 04:28 PM
04/14/10 04:28 PM
MoparforLife
Upper Midwest
You meant "Hub towing" right? And that's OK, I was just throwing some additional info out there since it hadn't been mentioned before as to the adverse affects of towing a vehicle with the D-shaft still in, in general. I know what "flat towing" with rear hubs is all about. Been there. don't do dat no mo.
Dean where did you start reading this thread. The whole thing has been related to the adverse effects of towing with the driveshaft hooked up and and spinning the transmission. And yes that is what I meant is "hub towing" buty a hell of alot simpleer to take out the drive shaft flange bolts and tape the joint and strap the shaft up out of the way and take off. ![](/ubbthreads/images/graemlins/confused.gif)
[Re: MoparforLife]
#667782
04/14/10 04:57 PM
04/14/10 04:57 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
OK, you win.......but if people are wondering what adverse affects occur when towing with the driveshaft in I thought no immediate crime would be committed to throw my ![](/ubbthreads/images/graemlins/Twocents.gif) in. I did read it from the start, but I'm the kind that likes to know why stuff actually happens. Just sharing....... ![](/ubbthreads/images/graemlins/wave.gif)
#667783
04/14/10 06:08 PM
04/14/10 06:08 PM
MoparforLife
Upper Midwest
OK, you win.......but if people are wondering what adverse affects occur when towing with the driveshaft in I thought no immediate crime would be committed to throw my in.
Just sharing.......
Just giving you some crap. I seem to be able to get enough that I just wanted to pass some around so no one gets left out. No hard feelings.
