'70 Challenger 383 Exhaust Manifold Attaching Hardware #66656
05/31/08 01:45 PM
05/31/08 01:45 PM
Rhode Island
71 Six Pack Offline OP
Rhode Island
I am in the process of putting HP manifolds on my '70 Challenger with 383. When I bought it the car had headers with bolts. I know the factory setup used studs and nuts, but I also know that some big blocks used sleeve nuts as well. What is the correct way to attach the factory HP manifold to a '70 383? If it uses sleeve nuts, what sizes and where do they go? Thanks,
Joe
Re: '70 Challenger 383 Exhaust Manifold Attaching Hardware [Re: 71 Six Pack] #66657
05/31/08 02:49 PM
05/31/08 02:49 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
here's an old pic of the '70 383 that's in my B-body. Pretty straight forward on what goes where once you start putting it together. Don't forget to seal the studs into the heads.
Edit: I just bought a stainless harware kit from one of the vendors... IIRC A+M
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: '70 Challenger 383 Exhaust Manifold Attaching Hardware [Re: R70RUNNER] #66658
05/31/08 02:59 PM
05/31/08 02:59 PM
Rhode Island
Rhode Island
Looks good! I already ordered the spark plug brackets, but wasn't sure if I needed the sleeve nuts or not. I have a set of 8 studs and regular nuts already. From the pic it looks like the last 2 studs have sleeve nuts on them. Is that a correct assumption?
The issue I have is none of my cars have the correct hardware. They either have headers and bolts, or exhaust manifolds with bolts. That being said I have nothing to reference on what is correct. I have seen the exhaust manifold kits, but they come with 8 studs, 8 nuts and 3 sleeve nuts. It sounds like its a universal blanket application, so I'm not sure which pieces I need to go with. Thanks for the pic.
Joe
Re: '70 Challenger 383 Exhaust Manifold Attaching Hardware [Re: 71 Six Pack] #66659
06/02/08 10:31 PM
06/02/08 10:31 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Nine nuts and three sleeve nuts with HP manifolds.The manifolds will show you where the sleeve nuts go.
Re: '70 Challenger 383 Exhaust Manifold Attaching Hardware [Re: 62maxwgn] #66660
06/02/08 10:57 PM
06/02/08 10:57 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Bill got to it, three sleeve nuts. 2 on the rt, 1 on the left
Re: '70 Challenger 383 Exhaust Manifold Attaching Hardware [Re: R70RUNNER] #66661
06/04/08 11:01 PM
06/04/08 11:01 PM
Rhode Island
Rhode Island
Thanks, I see now that the attaching kit uses all the pieces etc. I notice in the kit that the smaller sleeve nut does not have the hole in the top hex portion. Is this correct, or are all the sleeve nuts supposed to be hollow the whole length? Thanks again for the help.
Joe
