Page 1 of 3 1 2 3
493 RB Steet/Strip Combo, What Are Your Thoughts??? #664784
04/08/10 10:47 PM
04/08/10 10:47 PM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline OP
Hey guys just dropped my 73 cuda off with a great friend, he is going to put togeather a 493 (mancini Kit) RB for me while Im over seas for the next year. Just wanted to see what you guys think about the build and what type of power it will make. This will be a street driven car that will see a lot of track time.
1973 440 Block
4.15 Eagle Crank & Rods
Diamond Flat Top Pistons
Stealth Heads (Cleaned Up & Gasket Matched)
Roller Rockers 1.5
Comp Cam, Solid Roller: .600 lift
Comp Solid Roller lifters
Eddy Victor intake (matched to heads)
950 carb
2" Primary Headers/Full 3" exhaust
3500 stall
Looking to get about 10.1 to 11.1 comp. Want to run on pump gas.
Dana 60 cut to B-Body specs and 3.73 or 4.10 gear & New HD Springs with 1" relo kit, also getting subframe connectors put on. Going to go with 10" wide rims with ET streets or a similar tire.
My friend who is building the engine and taking care of all my stuff suggested I might want to switch to a smaller non roller solid (.566 lift) cam for my build. What are your guys thoughts? Thanks in advance.
Don
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664785
04/08/10 10:58 PM
04/08/10 10:58 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Sounds really close to my combo. Yours will probably dyno about 570-600HP with about 640TQ.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664786
04/08/10 11:31 PM
04/08/10 11:31 PM
IN
ahy Offline
ahy  Offline
IN
A few thoughts based on building a similar 496" B. 10 - 11 CR is the right range. Depending on cam, closer to 10.2-10.5 would work better on pump gas. This requires a dish piston. With a long duration cam and good quench 11 may work but that's pushing it. BB's don't like detonation and you have to finish the race to win.
If you want to get the most out of it on pump gas, build a zero deck engine with a common .040 head gasket to get arount .040 quench with a "D" dish to get compression where it needs to be.
The stock port style heads make more peak power and lower ET with a big cam and high stall convertor but drivability and fuel economy suffer. I think its more fun to have a more moderate cam + convertor and enjoy the mid range torque of the stroker.
On cam type, the roller can provide better performance and avoids the issue of low zinc oil. However, since the BB wasn't designed for a roller, component selection and setup are critical. Perhaps your builder isn't comfortable with this. I wouldn't be either for what is worth.
My setup has 10.2 CR and a .55 lift 243deg@.050 "fast" MM lobe mechanical flat tappet cam from Muscle Motors with comp "pro magnum" rockers. It works with the stock Ed springs. I run diesel engine oil + STP to get additional oil protection.
I guess it has 550 HP at around 5600 RPM. Torque builds quickly starting at around 2000 RPM. Mine's an manual transmission application. With an auto, a little extra stall vs stock would be needed for sharp performance but not much.
I guess I'd follow your builder's advice and go with a more moderate FT cam.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: ahy] #664787
04/08/10 11:49 PM
04/08/10 11:49 PM
Thanks for your thoughts, I guess I forgot to add that it will have a 3000-3500 stall and 2 inch primary headers and a full 3" exh through flow master 40's.
Street/Strip 73 Barracuda
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664788
04/09/10 04:56 AM
04/09/10 04:56 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
You mentioned track duty alot do you have an ET goal? at least your going dana from the start also some might want to know the cam timing events / specs to give you a better choice on compression I think the duration @ 50 and intake valve closing ABDC should be balanced with compression choice also so you dont bleed off too much and loosing some free ponies! whats the weight on that thing anyways
here is something for ya to play around with so you get a better feel for it... I would say "about" 9.0 to 1 dynamic is pump gas frendly
http://www.wallaceracing.com/dynamic-cr.php
Mopar Performance
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664789
04/09/10 07:53 AM
04/09/10 07:53 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'd buy him a copy of AndyF's book and let him read that first. What are you doing overseas for a year?
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: ahy] #664790
04/09/10 02:17 PM
04/09/10 02:17 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
My setup has 10.2 CR and a .55 lift [Email]243deg@.050[/Email] "fast" MM lobe mechanical flat tappet cam from Muscle Motors with comp "pro magnum" rockers. It works with the stock Ed springs. I run diesel engine oil + STP to get additional oil protection.
I had "reverse dome" Ross pistons in my 440 with B1-BS heads and 10 to 1 CR. My engine builder felt this gives the best quench on pump gas. The reverse dome is like a "mirror" of the combustion chamber and is measured in CCs for the CR you want.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: jbc426] #664791
04/09/10 02:27 PM
04/09/10 02:27 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664792
04/09/10 02:50 PM
04/09/10 02:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would look at a 4.25 stroke with BB Chevy rod journal sizes, this will increase the torque and HP s well as reduce the recriprocating weight, which will help the motor accelerate faster I have built several of these motors but not with those heads or cam. I would shoot for 10.5 to 1 compression
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: Cab_Burge] #664793
04/09/10 08:45 PM
04/09/10 08:45 PM
I appricate all the comments. Im pretty sure he has Andy's book, not that he would need it he has been building engines for 30 years. The car is stock cuda weight im guessing 3600 lbs. I would like to see low 11 sec qtr mile times.
What are your guys thoughts on switching out from the solid roller I have to a smaller solid cam?
Im in the Army and headed to Afganistan for the next year.
Here is the kit I got from Mancini:
http://chucker54.stores.yahoo.net/493440flpist.html
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664794
04/09/10 09:26 PM
04/09/10 09:26 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a solid roller cam in my 440 and so far I really like it. There is about 1500 hundred miles on the motor so far. I lashed The valves one time so far,but it did not need it.
Also since you asked, I think you should get a better set of heads like Indy EZs or SRs and open them up to a Max Wedge port window. That big of a motor needs a bigger head.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: Darryls-Demon] #664795
04/10/10 03:39 AM
04/10/10 03:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 440source heads are going to be your bottleneck. I would be looking at their CNC stealths instead of the base model heads. With unported CNC heads you will make a lot of torq, but I don't think you'll get much over 550hp out of it, at it will probably want to peak near 6000rpm.
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: DaytonaTurbo] #664796
04/10/10 07:20 AM
04/10/10 07:20 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I had a 440/499 with a solid roller 248/254 @ 50 at .614 / .620 gross lift with 1.6 rockers at the time. this was with ported iron heads 906s with 2.14/1.81 valves. car ran GREAT on pump gas and out on the street and was heavier than your car by a couple hundred... had a coan 3000 stall in it! at least with that solid roller and your ET goal your covered there I read posts on here all the time about people wanting to change from a solid cam to a roller cam!
Mopar Performance
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664797
04/10/10 11:00 AM
04/10/10 11:00 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello The Cuda Guy,
I would consider the 440 2D intake for that combo and keep the roller idea. I agree with the others about keeping it around the 10.5 mark and not hitting 11 on the cr. I would not go over 3200 on the stall and get the 3.73 gear.
Damon
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: mopardamo] #664798
04/10/10 03:48 PM
04/10/10 03:48 PM
Thanks for the comments guys, keep them coming.
Don
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: mopardamo] #664799
04/10/10 04:11 PM
04/10/10 04:11 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Hello The Cuda Guy,
Damon
x 2 on the dualplane,i have four of them.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: Old School] #664800
04/10/10 06:23 PM
04/10/10 06:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I'm suprised no one mentioned the 337 yet ! But atleast the 2d can go out to max wedge down the road if need be!
Mopar Performance
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: moparniac] #664801
04/10/10 07:10 PM
04/10/10 07:10 PM
Does anyone have a link to the 337? I have seriously concidered the Indy dual plane.
I guess the bottom line is that my engine builder will know what is best, I wanted to get some thoughts/opinions on the cam change should I keep the roller or go just solid with street/strip in mind.
Thanks for all the comments.
Don
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664802
04/10/10 07:36 PM
04/10/10 07:36 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Here is one from the Tech Archives about the 337. https://board.moparts.org/ubbthreads/show...e=1#Post4613252
I think it might also be a good manifold for your use. I would give the nod to the 2D in your application though. Go roller. Get the block set up for a roller and you will likely not have to do any block mod's in the future unless you really step it up.
Damon
Re: 493 RB Steet/Strip Combo, What Are Your Thoughts??? [Re: The Cuda Guy] #664803
04/10/10 07:36 PM
04/10/10 07:36 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Sounds pretty similar to my set up. M1 with lightly ported eddy heads and 625 solid roller. Started with 4.10 and went to 4.30 gears with 8" 3800 converter. Big help came (.3) when I switched from 950 to a 1050 4150 quick fuel. If you don't already have the 950 then by the 1050 right away. Your car is lighter than mine and probably a bigger tire (mine are 275-60-15)and I weigh almost 4300#. You may crack into the tens since mine is 11.15 on super stocks. Good luck and be carefull overseas. Thank You for your service!!!!!
Page 1 of 3 1 2 3
