Need pics for holes to be drilled #663825
04/07/10 06:29 PM
04/07/10 06:29 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
My car came back from the body shop with the holes welded up, but not re-drilled for the stainless around the front and back windows (these are the holes for the attaching clips). Now I have to re-drill the holes. Any one have good pics without the stainless and clips in place? Closeups and the whole areas (front windshield, back glass) would be helpfull.
Thanks,
Mike
Re: Need pics for holes to be drilled [Re: bigblock340power] #663826
04/07/10 08:59 PM
04/07/10 08:59 PM
Elk Grove, Calif.
Elk Grove, Calif.
Oh, come on people, someones got to have some pics. Help a Mopar brother out.
Re: Need pics for holes to be drilled [Re: bigblock340power] #663827
04/07/10 10:14 PM
04/07/10 10:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Are you sure they're welded and not bondo'd !!
Why would a bodyshop weld all those holes up ?!?!?!
Re: Need pics for holes to be drilled [Re: Stanton] #663828
04/08/10 02:15 AM
04/08/10 02:15 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yes they are welded. For some reason a lot of the holes were bad (would not hold the screws any more). So they all were welded.
Re: Need pics for holes to be drilled [Re: bigblock340power] #663829
04/08/10 03:23 AM
04/08/10 03:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Cool, car finally coming home, I like that. Hey, the method I have seen is to first use new clips with the bottom edge of the clip resting on the bottom of the channel. That should put them in the proper depth. as far as where to place each clip, I have 2 cars I can check and will be in the shop tomorrow, call me. I sit next to you at the CCM meetings selling raffle prizes, so you know who I am!
Re: Need pics for holes to be drilled [Re: bigblock340power] #663830
04/08/10 06:58 AM
04/08/10 06:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's not crital where they go, there is 13 of them on a E body. Don't know what kinda of car your working on.
Re: Need pics for holes to be drilled [Re: Challenger 1] #663831
04/08/10 10:24 AM
04/08/10 10:24 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
trying to drill through weld is tough, as said its not critical where they go just space them out evenly and try not to hit the welded holes.
Re: Need pics for holes to be drilled [Re: Kern Dog] #663832
04/08/10 10:37 AM
04/08/10 10:37 AM
Elk Grove, Calif.
Elk Grove, Calif.
Well you weren't there last Tuesday. We all missed your verbal banter. On the up side I did win the door prize. I seem the remember people calling you names on the way out of the meeting. HA! I'll call after 8:00 sometime.
Mike
PS I tried calling, nothing. All I have is your home #. I'll be sanding on the trunk.
Re: Need pics for holes to be drilled [Re: bigblock340power] #663833
04/10/10 08:47 AM
04/10/10 08:47 AM
Elk Grove, Calif.
Elk Grove, Calif.
Thanks to Frankenduster for letting me inspect his Dusters. Most helpful. Now on to the task at hand.
Re: Need pics for holes to be drilled [Re: bigblock340power] #663834
04/11/10 05:04 AM
04/11/10 05:04 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Well, anyone that knows me is aware that I like to help the "little people". hehehehehehe.
