caltrac users.controling wheelstands? #663104
04/06/10 08:42 PM
04/06/10 08:42 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
a- body mono leaf with caltracs.set up-per instructions.Motor makes alot more steam than last year.If wheel stands become a problem,any tips to keep it on the ground.t-n-t about 3 weeks away.Buddy is a bit nervous about the new powerplant, and being violant.any tips?
Re: caltrac users.controling wheelstands? [Re: moretoys] #663105
04/06/10 08:46 PM
04/06/10 08:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Might start with the front shocks set full tight(if they are adjustable) just to get an idea of what it will do.
68 Barracuda Formula S 340
Re: caltrac users.controling wheelstands? [Re: Bad340fish] #663106
04/06/10 08:50 PM
04/06/10 08:50 PM
BigFish69 Offline
BigFish69  Offline
wheelie bars
Re: caltrac users.controling wheelstands? [Re: Bad340fish] #663107
04/06/10 08:51 PM
04/06/10 08:51 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I wish i had that problem,,,lol
Re: caltrac users.controling wheelstands? [Re: moretoys] #663108
04/06/10 10:09 PM
04/06/10 10:09 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
When I asked John Calvert that question he said:
Softer hit (bottom hole, more preload)
Stiffer front shock settings
Limit travel on front
Stiffer torsion bars
Bill
Re: caltrac users.controling wheelstands? [Re: 69CHARGERMD] #663109
04/06/10 10:09 PM
04/06/10 10:09 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yea what he said !!
Re: caltrac users.controling wheelstands? [Re: VernMotor] #663110
04/06/10 10:32 PM
04/06/10 10:32 PM
Out West
408strokerdart Offline
Out West
Short shift and smile big It will eventually come down.
Seriously, use the front suspension to limit transfer. This rear suspension needs all the transfer it can get to work anyway, so it is easily controlled by limiters or adjustable shocks.
Re: caltrac users.controling wheelstands? [Re: 408strokerdart] #663111
04/06/10 11:12 PM
04/06/10 11:12 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
A set of AFCO front shocks fixed all of my control issues with the wheelies.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Post deleted by Defbob [Re: Irun5snd8th] #663112
04/06/10 11:19 PM
04/06/10 11:19 PM
Re: caltrac users.controling wheelstands? #663113
04/07/10 09:22 AM
04/07/10 09:22 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Don't do what I did and just hit it hard! We went from a suspension tune on motor which was loose in the front and tight in the back (car was pulling the front tires maybe 10") and did not adjust when we added the 100 shot of NOS. The results were not good! Car went up and I tried to short shift but must have lifted. We bought these nice shocks for the front but did not use them as we should have and now will have to pay the piper!!. I say start with a tight setting on the front so the car will have to work to get the front up. Start with a loose shock setting in the back so you can blow the tires, then work you way a click or two at a time until you get your desired results. If you make enough power you can tie down the front end and your car may not porpoise. The general tuning of hole placement from Cal tracs is also a good starting point. As said earlier a short shift will bring the front down, but does you no good if you are pointed towards the wall.
Good luck
Diego
Re: caltrac users.controling wheelstands? [Re: moretoys] #663114
04/07/10 09:26 AM
04/07/10 09:26 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If all else fails move some weight around.
Re: caltrac users.controling wheelstands? [Re: Diego_Ted] #663115
04/07/10 09:39 AM
04/07/10 09:39 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Good luck
Diego
Accually Ted the rear shocks were two clicks from full loose, set on #7 allowing more separation in the rear, planting the tire harder resulting in a dead hook and a big wheel stand
Re: caltrac users.controling wheelstands? [Re: formula S] #663116
04/07/10 09:54 AM
04/07/10 09:54 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Good luck
Diego
I stand corrected!! Results were the same?
