Re: caltrac users.controling wheelstands?
[Re: moretoys]
#663105
04/06/10 08:46 PM
04/06/10 08:46 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Might start with the front shocks set full tight(if they are adjustable) just to get an idea of what it will do.
68 Barracuda Formula S 340
[Re: VernMotor]
#663110
04/06/10 10:32 PM
04/06/10 10:32 PM
Posts: 3,456 Out West
408strokerdart
Out West
Short shift and smile big It will eventually come down. Seriously, use the front suspension to limit transfer. This rear suspension needs all the transfer it can get to work anyway, so it is easily controlled by limiters or adjustable shocks.
Post deleted by Defbob
[Re: Irun5snd8th]
#663112
04/06/10 11:19 PM
04/06/10 11:19 PM
#663113
04/07/10 09:22 AM
04/07/10 09:22 AM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Don't do what I did and just hit it hard! We went from a suspension tune on motor which was loose in the front and tight in the back (car was pulling the front tires maybe 10") and did not adjust when we added the 100 shot of NOS. The results were not good! Car went up and I tried to short shift but must have lifted. We bought these nice shocks for the front but did not use them as we should have and now will have to pay the piper!!. I say start with a tight setting on the front so the car will have to work to get the front up. Start with a loose shock setting in the back so you can blow the tires, then work you way a click or two at a time until you get your desired results. If you make enough power you can tie down the front end and your car may not porpoise. The general tuning of hole placement from Cal tracs is also a good starting point. As said earlier a short shift will bring the front down, but does you no good if you are pointed towards the wall. Good luck Diego
[Re: moretoys]
#663114
04/07/10 09:26 AM
04/07/10 09:26 AM
Posts: 8,165 Left Coast
BobR
Left Coast
a- body mono leaf with caltracs.set up-per instructions.Motor makes alot more steam than last year.If wheel stands become a problem,any tips to keep it on the ground.t-n-t about 3 weeks away.Buddy is a bit nervous about the new powerplant, and being violant.any tips?
If all else fails move some weight around.
[Re: Diego_Ted]
#663115
04/07/10 09:39 AM
04/07/10 09:39 AM
Posts: 660 San Diego
formula S
San Diego
Good luck
Diego
Accually Ted the rear shocks were two clicks from full loose, set on #7 allowing more separation in the rear, planting the tire harder resulting in a dead hook and a big wheel stand
[Re: formula S]
#663116
04/07/10 09:54 AM
04/07/10 09:54 AM
Diego_Ted
Diego-Town, CA
Good luck
Diego
I stand corrected!! Results were the same?
