Lockup vs. non-lockup Torqueflites #661337
04/05/10 01:31 AM
04/05/10 01:31 AM
Spokane Valley, Washington
stryker63 Offline OP
Hello again,
I will be running an 8 1/4" rear end in my '73 Duster (mildly built 5.2L Magnum).
I want to use an A904 or A999/A998 TF, but my question is...Lockup or non-Lockup?
The car will not be raced and won't see a dragstrip, but rather be more of an avenue cruiser and weekend driver.
Thanks again for any help.
Re: Lockup vs. non-lockup Torqueflites [Re: stryker63] #661338
04/05/10 07:57 AM
04/05/10 07:57 AM
scratchnfotraction Offline
non lock up for hot rodding
lock up for MPGs
I use a stock high stall lock up A999 in my 85 truck
it works and gives it some pep with the high stall TC
it should be fine for what you want to do,IMHO
Re: Lockup vs. non-lockup Torqueflites [Re: scratchnfotraction] #661339
04/05/10 11:12 AM
04/05/10 11:12 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought the problem with the lockup 3sp's is the lockup engages at a certain speed, regardless of throttle pressure, meaning at WOT the lockup clutch has to sustain the full hp of the engine. Either way, if you buy a lockup trans, there's a kit out there you can install to disable the lockup.
Re: Lockup vs. non-lockup Torqueflites [Re: DaytonaTurbo] #661340
04/05/10 02:59 PM
04/05/10 02:59 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It will only lockup in third so if you have it floored, it will only go into lockup after it settles into third. Without WOT, it locks at about 30 again, after it shifts to 3rd.
There is also a kit that delays the lockup to 40 mph to eliminate shudder with the lockup.
Craig
Re: Lockup vs. non-lockup Torqueflites [Re: denfireguy] #661341
04/05/10 03:08 PM
04/05/10 03:08 PM
at WOT going into 3rd the pressure is high enuff it hits 3rd already locked up
not good on the TC clutch
from what I have read anyways
Re: Lockup vs. non-lockup Torqueflites [Re: stryker63] #661342
04/05/10 06:15 PM
04/05/10 06:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The late 80's-on 904's have an electric input that will unlock the converter on command or prevent lockup if energized.
Re: Lockup vs. non-lockup Torqueflites [Re: stryker63] #661343
04/06/10 07:42 PM
04/06/10 07:42 PM
Locomotion Offline
Locomotion  Offline
One good thing about later lock-up 904's is that many had a 2.71 low gear set. I'm just not sure exactly what to look for or the years.
