Re: Lockup vs. non-lockup Torqueflites
[Re: DaytonaTurbo]
#661340
04/05/10 02:59 PM
04/05/10 02:59 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I thought the problem with the lockup 3sp's is the lockup engages at a certain speed, regardless of throttle pressure, meaning at WOT the lockup clutch has to sustain the full hp of the engine. Either way, if you buy a lockup trans, there's a kit out there you can install to disable the lockup.
It will only lockup in third so if you have it floored, it will only go into lockup after it settles into third. Without WOT, it locks at about 30 again, after it shifts to 3rd. There is also a kit that delays the lockup to 40 mph to eliminate shudder with the lockup. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: stryker63]
#661342
04/05/10 06:15 PM
04/05/10 06:15 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The late 80's-on 904's have an electric input that will unlock the converter on command or prevent lockup if energized.
