Column shifter off #660413
04/04/10 08:08 AM
04/04/10 08:08 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
My auto column shifter on a 70 383/727 RR is off by one.In other words sometimes reverse will be neutral,nuetral is drive,drive is low2 and so on.When I put in park it wont start,until I shift down.When I pull the shifter all the way down to low and back up to park it sometimes goes back to normal,but eventually starts over.I'm hoping it's just a linkage adjustment.Car is new to me as well as mopars,so I'm not as familiar with them.Thanks.
Re: Column shifter off [Re: tt455] #660414
04/04/10 10:17 AM
04/04/10 10:17 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
It's real easy to adjust the shifter linkage. Just unhook the shifter linkage at the transmission gear selector, put the car in park or first adjust linkage up until it slips in the gear selector and your done.
Re: Column shifter off [Re: moparpollack] #660415
04/04/10 10:50 AM
04/04/10 10:50 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks,I was hoping it was an easy fix.
Re: Column shifter off [Re: tt455] #660416
04/04/10 10:58 AM
04/04/10 10:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can look the linkage over for extra slop, and add washers if needed too.
Re: Column shifter off [Re: tt455] #660417
04/04/10 11:10 AM
04/04/10 11:10 AM
IMGTX Offline
IMGTX  Offline
He is right. It's an easy fix. But if it used to work right and now it acts funny. Something went wrong.
If you recently R&R'd the transmission, engine, or linkage pieces the adjustment is normal.
If not check the bushings at the ends of the cross shaft and the shift levers for wear or broken pieces. The cross shaft bushings are still available from Mopar and probably other places.
If the bushings are OK check the engine and transmission mounts.
I have never found that problem occur without some kind of recent repair that alters the adjustment or wear worn out parts.
Re: Column shifter off [Re: IMGTX] #660418
04/04/10 01:02 PM
04/04/10 01:02 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
I've only had the car a couple of days,but the previous owner said he only had this happen once when the car was at an incline.
Re: Column shifter off [Re: tt455] #660419
04/04/10 01:37 PM
04/04/10 01:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
sounds like the previous owner might have fibbed a little just to unload something he could not or would not fix. It happens. You should have no issues fixing your linkage.
Re: Column shifter off [Re: tt455] #660420
04/04/10 03:27 PM
04/04/10 03:27 PM
IMGTX Offline
IMGTX  Offline
It may be a bad motor or transmission mount if parking on an incline can cause it. Those going bad will cause the engine to shift under load.
It's still an easy fix but I would put it up on Stands and inspect the mounts and the shift bushings.
Re: Column shifter off [Re: IMGTX] #660421
04/18/10 06:56 PM
04/18/10 06:56 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
OK,it was an easy fix the linkage bolt was loose.Everything is lined up correctly now,but after a couple of days I noticed it doesn't start in park all the time.Today it started in park but moved forward,by the end of the day it will only start in neutral.Is it the neutral safety switch and if so where is it in theses B body cars?
Re: Column shifter off [Re: tt455] #660422
04/18/10 07:22 PM
04/18/10 07:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Still in the linkage ajustment. It is picky so give it another shot.
Re: Column shifter off [Re: stumpy] #660423
04/18/10 08:26 PM
04/18/10 08:26 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Are you sure? I was thinking NSS because of the jerking forward in park?
Re: Column shifter off [Re: tt455] #660424
04/18/10 08:53 PM
04/18/10 08:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The neutral saftey switch is controled by a cockscomb on the lever in the trans. If it works in neutral it should work in park. Park is a more sentive adjustment then neutral. If it's jerking forward in park then you have an internal trans problem. The NSS is just a push button and does nothing but ground the start circuit.
Re: Column shifter off [Re: stumpy] #660425
04/18/10 09:32 PM
04/18/10 09:32 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks for your help,I'll look into it.
