Re: Column shifter off
[Re: tt455]
#660414
04/04/10 10:17 AM
04/04/10 10:17 AM
moparpollack
Lil Herman
Lil Herman
85086
It's real easy to adjust the shifter linkage. Just unhook the shifter linkage at the transmission gear selector, put the car in park or first adjust linkage up until it slips in the gear selector and your done.
[Re: stumpy]
#660423
04/18/10 08:26 PM
04/18/10 08:26 PM
Posts: 93 New York
tt455
New York
Still in the linkage ajustment. It is picky so give it another shot.
Are you sure? I was thinking NSS because of the jerking forward in park?
[Re: stumpy]
#660425
04/18/10 09:32 PM
04/18/10 09:32 PM
Posts: 93 New York
tt455
New York
The neutral saftey switch is controled by a cockscomb on the lever in the trans. If it works in neutral it should work in park. Park is a more sentive adjustment then neutral. If it's jerking forward in park then you have an internal trans problem. The NSS is just a push button and does nothing but ground the start circuit.
Thanks for your help,I'll look into it.
