Mock up coil over shock...you guys will love this... #659156
04/02/10 06:02 PM
04/02/10 06:02 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well I wasn't ready to buy front coil over shocks for my duster yet, but I was at the point that I needed to fab up the brackets before paint. So I had to come up with something... After thinking for a little while, I made a trip to Lowes. Turns out 3" (I.D) schedule 30 PVC is very close to the final diameter of the coil over shocks ( 3 1/2" vs. 3 9/16") After some measuring, calculating, and cutting...this is what I came up with.
First you need a 3" Schedule 30 PVC cap, drill a hole in the end, and insert a Slip fit/Threaded 1/2 "T" fitting in the end.
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659157
04/02/10 06:03 PM
04/02/10 06:03 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Secure the "T" fitting with a threaded/slip 1/2 coupler
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659158
04/02/10 06:03 PM
04/02/10 06:03 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Repeat with a 2" PVC Cap, and the same "T" fitting.
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659159
04/02/10 06:04 PM
04/02/10 06:04 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
I inserted a piece of tubing to step down from 1/2" ID, down to 3/8's like a standard attachment bolt is. I just wired in the tube to keep it in place...
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659160
04/02/10 06:05 PM
04/02/10 06:05 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Then you need a Schedule 30 3" to 2" coupler. I ground the inner stop out, and carefully ground the Diameter so a 2" PVC tube could slide in and out...
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659161
04/02/10 06:06 PM
04/02/10 06:06 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Measure and cut your 2" and 3" PVC carefully (depending on the shock travel you're looking to duplicate) And wallah... cheap adjustable mock up shock!!!
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659162
04/02/10 06:07 PM
04/02/10 06:07 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659163
04/02/10 06:07 PM
04/02/10 06:07 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Installed for the mounting bracket mock up!
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659164
04/02/10 06:10 PM
04/02/10 06:10 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Last one... It really helped me ensure that I was putting the top mounting bracket in the right spot. Also, it allows me to buy the shocks at the very end of the project, so I can see where the ride height will truely end up, and figure out the correct shock length...
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659165
04/02/10 06:13 PM
04/02/10 06:13 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Pretty slick.
Yeah, it's got a smallblock.
Re: Mock up coil over shock...you guys will love this... [Re: 340B5] #659166
04/02/10 06:15 PM
04/02/10 06:15 PM
organ
maximum entropy Offline
organ
those look so good i would just use them.
Re: Mock up coil over shock...you guys will love this... [Re: maximum entropy] #659167
04/02/10 07:03 PM
04/02/10 07:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why'd you stop there ... a couple o-rings, a spring and some oil and you'd be done! Quitter !!!
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659168
04/02/10 07:45 PM
04/02/10 07:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty trick Scott
Re: Mock up coil over shock...you guys will love this... [Re: MR_P_BODY] #659169
04/02/10 08:04 PM
04/02/10 08:04 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Did you file for a Patent?...LOL
Tony
70 AARCuda Vitamin C
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659170
04/02/10 09:16 PM
04/02/10 09:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Now THAT`S using your noggin. Those are way cool AND way cheap....good job.
Re: Mock up coil over shock...you guys will love this... [Re: Thumperdart] #659171
04/02/10 09:24 PM
04/02/10 09:24 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Thats purty Kool
Just when I had thought i had seen it all
Re: Mock up coil over shock...you guys will love this... [Re: dizuster] #659172
04/02/10 09:55 PM
04/02/10 09:55 PM
ohio
bigblockrik Offline
bigblockrik  Offline
ohio
I like it! gotta remember that
Re: Mock up coil over shock...you guys will love this... [Re: bigblockrik] #659173
04/03/10 07:12 AM
04/03/10 07:12 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Pretty slick!
Re: Mock up coil over shock...you guys will love this... [Re: Dartin] #659174
04/03/10 07:20 AM
04/03/10 07:20 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
thats some good thinking
Re: Mock up coil over shock...you guys will love this... [Re: 1Fast340] #659175
04/03/10 07:53 AM
04/03/10 07:53 AM
NC
440Jim Offline
440Jim  Offline
NC
A little fab work can do wonders.
But you forgot the adjustment knob! LOL
