Well I wasn't ready to buy front coil over shocks for my duster yet, but I was at the point that I needed to fab up the brackets before paint. So I had to come up with something... After thinking for a little while, I made a trip to Lowes. Turns out 3" (I.D) schedule 30 PVC is very close to the final diameter of the coil over shocks ( 3 1/2" vs. 3 9/16") After some measuring, calculating, and cutting...this is what I came up with.
First you need a 3" Schedule 30 PVC cap, drill a hole in the end, and insert a Slip fit/Threaded 1/2 "T" fitting in the end.
