Disc Brake Conversion #646723
03/21/10 08:15 AM
03/21/10 08:15 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Hi Guys,
I'm converting my 68 Coronet to discs using the later model (73 charger) single pot calipers.
My question is..
Where does the wire spring clip fit?
Cheers
Simon
Keeping the Bee Buzzin'
Re: Disc Brake Conversion [Re: Simonic] #646724
03/21/10 08:55 AM
03/21/10 08:55 AM
central CT
cudazappa Online content
cudazappa  Online Content
central CT
are you using the pin type or slider calipers? On the pin type the wire clip is used to fasten the outboard pad to the caliper for installation, and the pins go through the little indents keeping it there for road use.
1971 Challenger
Re: Disc Brake Conversion [Re: Simonic] #646725
03/21/10 09:07 AM
03/21/10 09:07 AM
Hello Simon. It's been awhile & it looks like I'll be given the opportunity to bone up on the Kings English today. Cheers
Re: Disc Brake Conversion [Re: RapidRobert] #646726
03/21/10 09:35 AM
03/21/10 09:35 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Hi,
Gentlemen,here's a pic of the caliper installed
Re: Disc Brake Conversion [Re: RapidRobert] #646727
03/21/10 09:45 AM
03/21/10 09:45 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Hi Robert,
Yes you are right it has been a while,due to the economic climate in the uk at the moment i've not been able to do much with my car this year.
I got the disc conversion second hand from a guy in belgium and apart from that i've got a new engine bay wiring loom to fit and i also got some of the new colored seat belts from bea body parts.
How have you been getting on?
Cheers
Simon
Re: Disc Brake Conversion [Re: Simonic] #646728
03/21/10 09:56 AM
03/21/10 09:56 AM
How have you been getting on? Cheers
Simon
I just got a part time job which is always good for the ole self esteem and more money for Mopar parts and me and another Mopar head may be opening a Mopar eng/trans restoration facility if this wealthy individual follows thru so lately I have been getting on pretty good. With you being "over there" it reminds me of the time 15 yrs ago I had a chance to buy a 64 valiant convertible here in Lincoln that had been shipped over from down under w the steering wheel on the right hand side!
Re: Disc Brake Conversion [Re: Simonic] #646729
03/21/10 10:15 AM
03/21/10 10:15 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Not trying to be critical, but just wanting you to have the brakes on correctly so they will work properly. You need to swap your calipers from each side of the car that they are on, to the other side. You will proably have to swap spindle and all to do it. The bleeder screws need to be at the highest point possible to prevent air bubbles from being trapped in the calipers. The brake hoses will go behind the shocks when mounted correctly,and the ones you have might not be long enough. Cudazappa was correct in the reply about the clips. Good luck.
Re: Disc Brake Conversion [Re: RapidRobert] #646730
03/21/10 10:33 AM
03/21/10 10:33 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
A trans and engine repair shop sounds great,just your kind of thing i would guess.
i've heard the rumours about the 'right hand drive' conversions,they all sound pretty awful,with lots of linkages involved,i remember somebody once told me about a conversion that involved two sprockets and a chain drive for the steering!
Re: Disc Brake Conversion [Re: JDMopar] #646731
03/21/10 10:44 AM
03/21/10 10:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Calipers will have to be switched side-to-side. You may have problems with those hoses but Dr.Diff has a set to do that rear-mount caliper installation.
Here's a shot of that caliper (yes, its a long link !!):
http://www.autozone.com/autozone/catalog...p;parentId=44-0
Re: Disc Brake Conversion [Re: JDMopar] #646732
03/21/10 10:49 AM
03/21/10 10:49 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Hi JD.
I did wonder about that.
i've swapped the calipers side to side and the banjo bolt on the hose fouls on the shocker on full lock.
If i mount 'em the other way ie calipers towards the front of the shock as opposed to the rear i have no steering due the caliper fouling on the anti roll (sway)bar
Re: Disc Brake Conversion [Re: Simonic] #646733
03/21/10 10:51 AM
03/21/10 10:51 AM
This was an actual factory RH drive car that someone locally here had brought in from Australia.
Re: Disc Brake Conversion [Re: Simonic] #646734
03/21/10 10:57 AM
03/21/10 10:57 AM
AndyF Offline
AndyF  Offline
Best bet will be to change calipers to one with a better hose routing.
Re: Disc Brake Conversion [Re: AndyF] #646735
03/21/10 11:07 AM
03/21/10 11:07 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Andy,
I think you are probably saying what i'm thinking.
I bought these fro a guy who said they were 68 Coronet when what he actually meant was that they had been fitted to a 68 coronet by somebody else.
i think i might just put my drums back on a give them a good seeing to
Re: Disc Brake Conversion [Re: Simonic] #646736
03/21/10 11:11 AM
03/21/10 11:11 AM
AndyF Offline
AndyF  Offline
The disc brakes will work fine, you just need to find a more appropriate set of calipers. There were a number of pin drive calipers made that will fit, the trick is finding the one with the best hose routing for a rear hung application.
Re: Disc Brake Conversion [Re: Simonic] #646737
03/21/10 11:22 AM
03/21/10 11:22 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunatley, I don't know of any pin type calipers that can be mounted toward the rear and used with 10.95" rotors.
I normally switch to 10.95" slider calipers and caliper brackets, or convert to 11.75" rotors and caliper brackets.
Re: Disc Brake Conversion [Re: DoctorDiff] #646738
03/21/10 02:17 PM
03/21/10 02:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
????? Ok, I'm asking out of curiosity ...
What difference does the rotor size make when it comes to lines? Why wouldn't the lines you (Dr.Diff) sold me for my 11.75" rear-mount pin-style swap work in this situation ??
Re: Disc Brake Conversion [Re: Stanton] #646739
03/21/10 07:12 PM
03/21/10 07:12 PM
central CT
central CT
just a followup on the wire clip: see attached..
1971 Challenger
Re: Disc Brake Conversion [Re: Simonic] #646740
03/21/10 10:19 PM
03/21/10 10:19 PM
JDMopar Offline
JDMopar  Offline
Hi JD.
I see the delimna your in now. Don't give up on the disc brakes though. They are much safer,and worth the trouble. If you end up switching to slider type calipers,and can't find any on your side of the pond....send me a PM. I've got a set of caliper adapters you can have for free. Not sure if shipping would be out the wazoo,as I've never shipped anything to the UK. Good luck.
Re: Disc Brake Conversion [Re: DoctorDiff] #646741
03/21/10 11:00 PM
03/21/10 11:00 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Granted, my car is a 66 but I used the smaller rotors (Thought I wanted to run 14" wheels) with a 72 B-body caliper mounted to the rear. I used 79 diplomat hoses (long!) with the mid-bracket removed from the hose and the banjo head profiled a touch. Later on, on my other 66, I used the larger rotors same 72 B-body calipers mounted to the rear and 78 Cordoba hoses. Just my
The 72 B-body calipers are intended for the hose to screw into it but will accept the "banjo" arrangement.
Re: Disc Brake Conversion [Re: Stanton] #646742
03/21/10 11:53 PM
03/21/10 11:53 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, the head of the banjo bolt scrapes the lower control arm at full lock, when the shorter caliper bracket and late B-body (banjo style) pin calipers are mounted toward the rear.
As mentioned, everything may clear if you can get a banjo hose to work with the '70-'72 B/E body calipers, which were originally intended for a straight, screw-in hose.
