Re: Sure Grip even tho wheels spin opposite directions?
[Re: Moparmaniacc]
#64277
05/26/08 09:48 PM
05/26/08 09:48 PM
If you can turn one rear wheel by hand, with the car in gear, or if the wheels turn opposite, you do NOT have a sure grip, or else it's pretty "broke." I spose it's possible that the clutches could be so worn that you could turn one, but I've never seen one that bad.
You might just be lucky---you might have a car with just the right transfer and tires to hook up with both tires.
#64278
05/26/08 09:52 PM
05/26/08 09:52 PM
you never heard of a "poor man's posi"?
#64279
05/26/08 10:10 PM
05/26/08 10:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Yeah but they won't spin the wheels one in each direction. Unless you know of one that I don't.
[Re: MoparforLife]
#64280
05/26/08 10:17 PM
05/26/08 10:17 PM
seen lotsa open diffs that spin tires in opposite directions.
#64281
05/27/08 07:52 AM
05/27/08 07:52 AM
MoparforLife
Upper Midwest
They all do as far as I know. Point being he is wondering if he has a ssure grip being he laid 2 strips even if turning the wheels with the car in the air the wheels turned opposite directions. The rest of us are saying that under the right conditions an open rear will lay down 2 strips for a short distance before 1 quits.
[Re: MoparforLife]
#64282
05/27/08 08:18 AM
05/27/08 08:18 AM
yah i understand what the rest of you is saying. and yes even a cooked suregrip will still move both tires in the same direction. the "poor man posi" thing is a trick back in the day to make a open diff act like a suregrip (nothing to do with welding the spider gears).
#64283
05/27/08 08:42 AM
05/27/08 08:42 AM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
how was it done never heard of that .
as far as the wheels turning in opposite directions , if the conetype is spent it's possible , but if you put enough power to it even an open can lay 2 strips , i have done it with a 340 when not taking off exactly straight .
[Re: JohnRR]
#64284
05/27/08 09:03 AM
05/27/08 09:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
my V6 dakota would put down 2 even patches and it was an open diff.
I had to do a 4000 rpm clutch drop to get both spinning though. if I went around a corner or was just driving normally on wet roads, only 1 would spin.
what is this poor mans posi you speak of?
**Photobucket sucks**
[Re: JohnRR]
#64285
05/27/08 05:12 PM
05/27/08 05:12 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
[Re: Pacnorthcuda]
#64287
05/27/08 05:58 PM
05/27/08 05:58 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
FWIW, a GM Corporate "Gov-Loc" will spin the wheels in the opposite direction when raised, but will lock up at a certain RPM. Doesnt help this siutation though does it? Will a detroit locker spin in the opposite direction when raised? I understand those are available now for an 8.75 rear. Gov-Locs are junk.
[Re: Pacnorthcuda]
#64289
05/27/08 07:24 PM
05/27/08 07:24 PM
I think there talking about the old trick of shimming the side gears into the spiders on an open diff. It would create enough bind to actually mimic a sure-grip to a degree. Would also wear very fast.
actually, its preloading the pass rear with a air shock. nice trick, works well.
#64290
05/28/08 10:38 AM
05/28/08 10:38 AM
JohnRR
U.S.S.A.
how do you get an air shock inside the diff housing ???
oh , no luck on that coupler
[Re: JohnRR]
#64291
05/29/08 12:33 AM
05/29/08 12:33 AM
in the diff? how'd you come up with that? anyways, airshock to replace the stock shock on the pass side. pump her up and its done. coupler.. no biggie.
#64292
05/29/08 08:37 AM
05/29/08 08:37 AM
JohnRR
U.S.S.A.
that was a joke
