Sure Grip even tho wheels spin opposite directions? #64275
05/26/08 09:39 PM
05/26/08 09:39 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I had always assumed the pumpkin in my 8 3/4" rear (489 type)was not a sure grip cuz the wheels spun in opposite directions when the rear was jacked up. Now that I have the 440 running decent enough, I was pleased to see tonight that I was leaving two strips down Can someone set me straight?
Re: Sure Grip even tho wheels spin opposite directions? [Re: Moparmaniacc] #64276
05/26/08 09:45 PM
05/26/08 09:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If the wheels turn opposite directions when you turn them in the air it is open. The traction was such that both wheels broke loose for a while but I would lay odds that one quit before the other or would have if you would have stayed in it long enough.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Sure Grip even tho wheels spin opposite directions? [Re: Moparmaniacc] #64277
05/26/08 09:48 PM
05/26/08 09:48 PM
If you can turn one rear wheel by hand, with the car in gear, or if the wheels turn opposite, you do NOT have a sure grip, or else it's pretty "broke." I spose it's possible that the clutches could be so worn that you could turn one, but I've never seen one that bad.
You might just be lucky---you might have a car with just the right transfer and tires to hook up with both tires.
Re: Sure Grip even tho wheels spin opposite directions? #64278
05/26/08 09:52 PM
05/26/08 09:52 PM
you never heard of a "poor man's posi"?
Re: Sure Grip even tho wheels spin opposite directions? #64279
05/26/08 10:10 PM
05/26/08 10:10 PM
Upper Midwest
Upper Midwest
Yeah but they won't spin the wheels one in each direction. Unless you know of one that I don't.
Re: Sure Grip even tho wheels spin opposite directions? [Re: MoparforLife] #64280
05/26/08 10:17 PM
05/26/08 10:17 PM
seen lotsa open diffs that spin tires in opposite directions.
Re: Sure Grip even tho wheels spin opposite directions? #64281
05/27/08 07:52 AM
05/27/08 07:52 AM
Upper Midwest
Upper Midwest
They all do as far as I know. Point being he is wondering if he has a ssure grip being he laid 2 strips even if turning the wheels with the car in the air the wheels turned opposite directions. The rest of us are saying that under the right conditions an open rear will lay down 2 strips for a short distance before 1 quits.
Re: Sure Grip even tho wheels spin opposite directions? [Re: MoparforLife] #64282
05/27/08 08:18 AM
05/27/08 08:18 AM
yah i understand what the rest of you is saying. and yes even a cooked suregrip will still move
both tires in the same direction. the "poor man posi" thing is a trick back in the day to
make a open diff act like a suregrip (nothing to do with welding the spider gears).
Re: Sure Grip even tho wheels spin opposite directions? #64283
05/27/08 08:42 AM
05/27/08 08:42 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
how was it done never heard of that .
as far as the wheels turning in opposite directions , if the conetype is spent it's possible , but if you put enough power to it even an open can lay 2 strips , i have done it with a 340 when not taking off exactly straight .
Re: Sure Grip even tho wheels spin opposite directions? [Re: JohnRR] #64284
05/27/08 09:03 AM
05/27/08 09:03 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my V6 dakota would put down 2 even patches and it was an open diff.
I had to do a 4000 rpm clutch drop to get both spinning though. if I went around a corner or was just driving normally on wet roads, only 1 would spin.
what is this poor mans posi you speak of?
**Photobucket sucks**
Re: Sure Grip even tho wheels spin opposite directions? [Re: JohnRR] #64285
05/27/08 05:12 PM
05/27/08 05:12 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Re: Sure Grip even tho wheels spin opposite directions? [Re: rrunner] #64286
05/27/08 05:46 PM
05/27/08 05:46 PM
Kirkland, Washington
Pacnorthcuda Offline
I think there talking about the old trick of shimming the side gears into the spiders on an open diff. It would create enough bind to actually mimic a sure-grip to a degree. Would also wear very fast.
Re: Sure Grip even tho wheels spin opposite directions? [Re: Pacnorthcuda] #64287
05/27/08 05:58 PM
05/27/08 05:58 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
FWIW, a GM Corporate "Gov-Loc" will spin the wheels in the opposite direction when raised, but will lock up at a certain RPM.
Doesnt help this siutation though does it?
Will a detroit locker spin in the opposite direction when raised? I understand those are available now for an 8.75 rear.
Gov-Locs are junk.
Re: Sure Grip even tho wheels spin opposite directions? [Re: NTOLERANCE] #64288
05/27/08 06:05 PM
05/27/08 06:05 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
Gov-Locs are junk.
a locker no a tru trac yes...and gov-locs are in fact junk!!! sounds like hes got a cone grip thats whiped...ive had them do that...jack it up in park or hold the d shaft and see how hard it is to turn...open should real easy a wasted grip a lil harder...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Sure Grip even tho wheels spin opposite directions? [Re: Pacnorthcuda] #64289
05/27/08 07:24 PM
05/27/08 07:24 PM
actually, its preloading the pass rear with a air shock. nice trick, works well.
Re: Sure Grip even tho wheels spin opposite directions? #64290
05/28/08 10:38 AM
05/28/08 10:38 AM
how do you get an air shock inside the diff housing ???
oh , no luck on that coupler
Re: Sure Grip even tho wheels spin opposite directions? [Re: JohnRR] #64291
05/29/08 12:33 AM
05/29/08 12:33 AM
in the diff? how'd you come up with that? anyways, airshock to replace the stock shock on the pass side.
pump her up and its done. coupler.. no biggie.
Re: Sure Grip even tho wheels spin opposite directions? #64292
05/29/08 08:37 AM
05/29/08 08:37 AM
that was a joke
