Ebody Steering Column Replace ignition switch Help #642500
03/16/10 10:23 PM
03/16/10 10:23 PM
Arizona
717071CHALLENGER Offline OP
Arizona
Hello
I,m Trying to change ignition switch in a 71 challenger.It is calling for special tool C-3044 To pull bearing and housing from shaft.Anyone use this tool ot have any suggestions on getting the bearing and housing off that hold the ignition switch
Thanks Randy
Re: Ebody Steering Column Replace ignition switch Help [Re: 717071CHALLENGER] #642501
03/16/10 11:07 PM
03/16/10 11:07 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I used a harbor freight puller. It fits in the crush can and pulls the can right off. It also has the lock plate depressor to get that off. Then push the pin and it is out.
Craig
Re: Ebody Steering Column Replace ignition switch Help [Re: denfireguy] #642502
03/16/10 11:13 PM
03/16/10 11:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Ebody Steering Column Replace ignition switch Help [Re: 717071CHALLENGER] #642503
03/16/10 11:20 PM
03/16/10 11:20 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Ebody Steering Column Replace ignition switch Help [Re: Snoopy] #642504
03/17/10 09:55 AM
03/17/10 09:55 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I never have used any speciall tool beside just the steering puller and snap ring plyers
Re: Ebody Steering Column Replace ignition switch Help [Re: NachoRT74] #642505
03/17/10 10:15 AM
03/17/10 10:15 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
theres a member selling that tool in the for sale section.
Re: Ebody Steering Column Replace ignition switch Help [Re: 717071CHALLENGER] #642506
03/17/10 10:44 PM
03/17/10 10:44 PM
IMGTX Offline
IMGTX  Offline
I never needed the tool either.
Once you remove the snap ring and the screws that hold the upper to the middle housing, simply pull on the upper housing. If it doesn't come off then place two screwdrivers (one on each side) between the upper and middle housings. Gently pry the upper housing off.
Works like a charm.
Re: Ebody Steering Column Replace ignition switch Help [Re: IMGTX] #642507
03/18/10 12:05 AM
03/18/10 12:05 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or simply using a rubber mallet at a side and will come off too easy to be pulled by hands. I had never needed to make it, but just in case is needed.
