Ebody Steering Column Replace ignition switch Help
#642500
03/16/10 10:23 PM
03/16/10 10:23 PM
Posts: 30 Arizona
717071CHALLENGER
Arizona
Hello I,m Trying to change ignition switch in a 71 challenger.It is calling for special tool C-3044 To pull bearing and housing from shaft.Anyone use this tool ot have any suggestions on getting the bearing and housing off that hold the ignition switch Thanks Randy
Re: Ebody Steering Column Replace ignition switch Help
[Re: 717071CHALLENGER]
#642501
03/16/10 11:07 PM
03/16/10 11:07 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I used a harbor freight puller. It fits in the crush can and pulls the can right off. It also has the lock plate depressor to get that off. Then push the pin and it is out. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Snoopy]
#642504
03/17/10 09:55 AM
03/17/10 09:55 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I never have used any speciall tool beside just the steering puller and snap ring plyers
[Re: IMGTX]
#642507
03/18/10 12:05 AM
03/18/10 12:05 AM
NachoRT74
Valencia, España
or simply using a rubber mallet at a side and will come off too easy to be pulled by hands. I had never needed to make it, but just in case is needed.
