Re: Will this car leave straight? Corner weights--
[Re: wheelsup68dart]
#640457
03/14/10 10:02 PM
03/14/10 10:02 PM
with the correct weight in the drivers seat, you'll need 30 to 50 lbs. heavier on the right rear to get it to go straight. i think with your current weight you'll go to the right. ![](/ubbthreads/images/graemlins/Twocents.gif)
#640459
03/14/10 10:05 PM
03/14/10 10:05 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
30-50 pounds on right rear is very similar to 30-50 pounds heavier on left front ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: rt66jim]
#640460
03/14/10 10:07 PM
03/14/10 10:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I expect it to go to the right with those weights, how hard it will go right I cant say, but if its got a lot of torque it will go right harder than if it had lower torque levels...... and this is assuming you did the weights with the driver in the seat and at race weight ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#640461
03/14/10 10:20 PM
03/14/10 10:20 PM
car needs more weight on the right rear because it wants to drive to the right.by putting more weight on the right will get it to go straight. the front has nothing to do with driveability, you are just setting ride height with the front.as long as you get them close. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rt66jim]
#640463
03/14/10 10:42 PM
03/14/10 10:42 PM
MR_P_BODY
Those #'s are with the driver in the seat. Do you think it will wheelstand? 505 w/Ebrock heads, 550ish cam, Team G intake, 1000 HP carb and Hooker fenderwell headers. The converter is a TA model J that flashes 5000/5200. The owner is worried about big wheelstands. I'm thinking it make have too much weight on the front.
Its a big calculation to figure out if it will wheel stand or not... but it is a math formula ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rt66jim]
#640465
03/14/10 10:54 PM
03/14/10 10:54 PM
MR_P_BODY
Well I have a calc. her by the keyboard. What's the formula Mike?
I'll have to look it up.... in the Dave Morgan seminar he has it on his hand out(thats what I have to find) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#640466
03/14/10 10:57 PM
03/14/10 10:57 PM
Posts: 2,527 PA
moparacer
PA
I agree with the others.
Needs more weight on the RR.
You will find out the first pass if it does or not. The harder it leaves the more you will need.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
#640469
03/14/10 11:36 PM
03/14/10 11:36 PM
Easiest formula would be to just start with ladder bar fronts in the upper most holes, and move down as traction dictates. If it wheelstands from that setting then gonna have to limit travel and work on shocks from there.
theres more to it than that. if your in the upper most hole and start bringing that bar down,you'll need to reset your pinion angle.
if i were you i'd just put a little more preload on the RR and try it out and go from there. ![](/ubbthreads/images/graemlins/Twocents.gif)
#640470
03/14/10 11:59 PM
03/14/10 11:59 PM
Posts: 266 iowa
rook440
iowa
I always start out with the ladder bars in the middle hole ,,and quite frankly have never used the top hole in the front mount ,put it in the middle and start with you shock settings in the middle then move all the way up stiff on the next pass and all the other way on the next,,,go by your 60' and see what they do and adjust accordingly ,,,,, when I want to take more weight off of he front i move the front mountdown a hole ,that for me settles the car down and soffens the leave ,,you will of course have to adjust your pinion angle with each ladder bar change ,,,, and start over with your shock settings again going by your 60' ...this is what works for me ....good luck
[Re: rt66jim]
#640472
03/15/10 01:29 PM
03/15/10 01:29 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Helped scale a friends car today. 71 Dart 505BB, Dana w/4.10's, TF. It's a back-half ladder bar rear. 3045 lbs w driver. LF 918 RF 851 LR 641 RR 635. It's heavier than I would have expected. For a car with a glass front end. Do you think it will leave straight and drive straight with this setup? Jim
These weights are very similar to other BB A body lader bar cars that I have owned and driven Cars go straight arrrow, so easy that a cave man can drive em All kidding asise those numbers are typical of a lot of BB A body ladder bar cars, go run it. the wheelie hieghts and distances will be determine by track conditions, tires, stall leaving the line and several other factors like front and rear shock adjustments and travel ![](/ubbthreads/images/graemlins/scope.gif)
[Re: Dale]
#640473
03/15/10 04:27 PM
03/15/10 04:27 PM
If it were mine I would add 20 or 30 pounds to the right rear this will make it leave strait and also pull some off the left front and even out the front end weights.
exactly! ![](/ubbthreads/images/graemlins/beer.gif)
