Will this car leave straight? Corner weights-- #640455
03/14/10 09:53 PM
03/14/10 09:53 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Helped scale a friends car today. 71 Dart 505BB, Dana w/4.10's, TF. It's a back-half ladder bar rear. 3045 lbs w driver. LF 918 RF 851 LR 641 RR 635. It's heavier than I would have expected. For a car with a glass front end. Do you think it will leave straight and drive straight with this setup? Jim
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640456
03/14/10 09:56 PM
03/14/10 09:56 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Looks like a good starting setup to me.
Re: Will this car leave straight? Corner weights-- [Re: wheelsup68dart] #640457
03/14/10 10:02 PM
03/14/10 10:02 PM
with the correct weight in the drivers seat, you'll need 30 to 50 lbs. heavier on the right rear to get it to go straight. i think with your current weight you'll go to the right.
Re: Will this car leave straight? Corner weights-- [Re: wheelsup68dart] #640458
03/14/10 10:03 PM
03/14/10 10:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well if that was with driver in seat and fuel in ..set up like it was ready to go down the track..I agree with lonnie..that look like good numbers..to start out with.
Re: Will this car leave straight? Corner weights-- #640459
03/14/10 10:05 PM
03/14/10 10:05 PM
Columbus, Ohio
Columbus, Ohio
30-50 pounds on right rear is very similar to 30-50 pounds heavier on left front
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640460
03/14/10 10:07 PM
03/14/10 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I expect it to go to the right with those weights, how
hard it will go right I cant say, but if its got a lot
of torque it will go right harder than if it had lower
torque levels...... and this is assuming you did the
weights with the driver in the seat and at race weight
Re: Will this car leave straight? Corner weights-- [Re: MR_P_BODY] #640461
03/14/10 10:20 PM
03/14/10 10:20 PM
car needs more weight on the right rear because it wants to drive to the right.by putting more weight on the right will get it to go straight.
the front has nothing to do with driveability, you are just setting ride height with the front.as long as you get them close.
Re: Will this car leave straight? Corner weights-- #640462
03/14/10 10:33 PM
03/14/10 10:33 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Those #'s are with the driver in the seat. Do you think it will wheelstand? 505 w/Ebrock heads, 550ish cam, Team G intake, 1000 HP carb and Hooker fenderwell headers. The converter is a TA model J that flashes 5000/5200. The owner is worried about big wheelstands. I'm thinking it make have too much weight on the front.
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640463
03/14/10 10:42 PM
03/14/10 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a big calculation to figure out if it will wheel
stand or not... but it is a math formula
Re: Will this car leave straight? Corner weights-- [Re: MR_P_BODY] #640464
03/14/10 10:50 PM
03/14/10 10:50 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I have a calc. her by the keyboard. What's the formula Mike?
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640465
03/14/10 10:54 PM
03/14/10 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll have to look it up.... in the Dave Morgan seminar
he has it on his hand out(thats what I have to find)
Re: Will this car leave straight? Corner weights-- [Re: MR_P_BODY] #640466
03/14/10 10:57 PM
03/14/10 10:57 PM
PA
moparacer Offline
moparacer  Offline
PA
I agree with the others.
Needs more weight on the RR.
You will find out the first pass if it does or not. The harder it leaves the more you will need.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640467
03/14/10 10:58 PM
03/14/10 10:58 PM
Columbus, Ohio
Columbus, Ohio
Easiest formula would be to just start with ladder bar fronts in the upper most holes, and move down as traction dictates. If it wheelstands from that setting then gonna have to limit travel and work on shocks from there.
Re: Will this car leave straight? Corner weights-- [Re: MR_P_BODY] #640468
03/14/10 10:59 PM
03/14/10 10:59 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Ok thanks Mike.
Re: Will this car leave straight? Corner weights-- [Re: wheelsup68dart] #640469
03/14/10 11:36 PM
03/14/10 11:36 PM
theres more to it than that. if your in the upper most hole and start bringing that bar down,you'll need to reset your pinion angle.
if i were you i'd just put a little more preload on the RR and try it out and go from there.
Re: Will this car leave straight? Corner weights-- #640470
03/14/10 11:59 PM
03/14/10 11:59 PM
iowa
rook440 Offline
rook440  Offline
iowa
I always start out with the ladder bars in the middle hole ,,and quite frankly have never used the top hole in the front mount ,put it in the middle and start with you shock settings in the middle then move all the way up stiff on the next pass and all the other way on the next,,,go by your 60' and see what they do and adjust accordingly ,,,,, when I want to take more weight off of he front i move the front mountdown a hole ,that for me settles the car down and soffens the leave ,,you will of course have to adjust your pinion angle with each ladder bar change ,,,, and start over with your shock settings again going by your 60' ...this is what works for me ....good luck
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640471
03/15/10 07:57 AM
03/15/10 07:57 AM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
If it were mine I would add 20 or 30 pounds to the right rear this will make it leave strait and also pull some off the left front and even out the front end weights.
Re: Will this car leave straight? Corner weights-- [Re: rt66jim] #640472
03/15/10 01:29 PM
03/15/10 01:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
These weights are very similar to other BB A body lader bar cars that I have owned and driven Cars go straight arrrow, so easy that a cave man can drive em All kidding asise those numbers are typical of a lot of BB A body ladder bar cars, go run it. the wheelie hieghts and distances will be determine by track conditions, tires, stall leaving the line and several other factors like front and rear shock adjustments and travel
Re: Will this car leave straight? Corner weights-- [Re: Dale] #640473
03/15/10 04:27 PM
03/15/10 04:27 PM
exactly!
Re: Will this car leave straight? Corner weights-- #640474
03/15/10 05:09 PM
03/15/10 05:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
theres no way to tell what the car is going to do by looking at the weights unless they are completely out of wack. looks close enough to me. go run it and find out what it does and adjust from there.
