Page 1 of 3 1 2 3
A12 Identification #638821
03/13/10 01:40 PM
03/13/10 01:40 PM
Pugetroplis WA
RallyeMike Offline OP
Pugetroplis WA
I have found what is 99% chance an A12 Bee derelict with no fenders, grill, or drive train. Not sure if the body tag is present. The car is tucked away in a small town and friends of mine remember it new as an A12 from the 70's.
The property owner where it sits says he thinks the non-resident owner will sell it now, so I'm going to pursue it. What are 4 or 5 quick things to look at to tell positively it is an A12 car?
I appreciate the help !
"My top end is uuuuunlimited!"
Re: A12 Identification [Re: RallyeMike] #638822
03/13/10 01:52 PM
03/13/10 01:52 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
A few:
5th digit an "M"
DANA rear
2 extra 1/2 leaves on right side
spacers (about 1/8 inch thick) under lower control arm bumpers
unique engine harness with the idle solenoid wire going to passenger side
[oo]======[oo]
Re: A12 Identification [Re: Scatransit] #638823
03/13/10 02:04 PM
03/13/10 02:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No hood hinges - four hood pins instead.
Re: A12 Identification [Re: Scatransit] #638824
03/13/10 02:04 PM
03/13/10 02:04 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
All A12's have an oval filler hole
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: A12 Identification [Re: mopargem] #638825
03/13/10 04:27 PM
03/13/10 04:27 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Make sure the 5th digit in the VIN# is an "M" which is the 440+6 engine. Write down the entire VIN# for my A12 database.
I agree with everyone above except for the leaf springs. I have Broadcast sheet documentation on many of the early build A12 cars where they were delivered with the standard Rallye suspension, 5 leafs per side. 99% of them have the Hemi suspension with 7 leafs on the passenger side though.
Re: A12 Identification [Re: Dave Watt] #638826
03/13/10 05:14 PM
03/13/10 05:14 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
...I agree with everyone above except for the leaf springs. I have Broadcast sheet documentation on many of the early build A12 cars where they were delivered with the standard Rallye suspension, 5 leafs per side. 99% of them have the Hemi suspension with 7 leafs on the passenger side though...
I'm not sure how complete this car is, and I was speaking in general terms in an effort to help give him things to look for. We all know there are lots of things that could be argued with respect to authentication of these cars (any MOPAR really). Another example would be an "H" instead of "M" etc.
Also it should have the larger 26" radiator opening in the core support...As well as no provisions in the firewall for A/C...
[oo]======[oo]
Re: A12 Identification [Re: Scatransit] #638827
03/13/10 05:28 PM
03/13/10 05:28 PM
Pugetroplis WA
Pugetroplis WA
There is no drive train including the axle, so the leaf sprigs would be in question anyhow. Hood hinges can be removed, pins can be added, etc. All good stuff, but things like the solenoid wire .... Great stuff!
It's been awhile since I have been into B-bodies of this era. Is the oval gas filler hole a gag or is this really true? Why would they do that only on A12 cars?
Any more obscure items to look for?
Re: A12 Identification [Re: RallyeMike] #638828
03/13/10 05:55 PM
03/13/10 05:55 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
they did it on all cars built after jan of 69
a12 cars were built after jan of 69
alot of the things that are listed here are most likely long gone on a gutted out a12 car.
what you should look for is the
obvious m in the vin number on the dash vin tag
does it have a fender tag ???
if yes, does it match the vin tag on the dash??
after looking for or at the fender tag,
then look at the the front rad support and see if
the last 6 digits of the vin with a 9a before it is stamped in to it.
then you should go to the driver side trunk gutter and under
the trunk lid seal should be those same numbers stamped in it as on the rad support.
if those numbers match up
you have a a12 car
good luck
ps
bring back pics and numbers please
Re: A12 Identification [Re: flypaper] #638829
03/13/10 06:17 PM
03/13/10 06:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
26 inch radiator opening,all were 3 speed wipers
I think all A12 cars are 4 wheel drum brakes??
Re: A12 Identification [Re: flypaper] #638830
03/13/10 07:25 PM
03/13/10 07:25 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
then look at the the front rad support and see if the last 6 digits of the vin with a 9a before it is stamped in to it.
you have a a12 car
Not to split hairs but to give accurate information, the numbers on the radiator support and trunk lip will actually be stamped A9 XXXXXX.
Re: A12 Identification [Re: Scatransit] #638831
03/13/10 07:32 PM
03/13/10 07:32 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
A few:
5th digit an "M"
DANA rear
I think your suggestion about the 1/8" spacers under the rubber bumpers on the lower control arms is the best suggestion yet for a car that may be missing eveery other form of identification. It's unlikely anybody would have removed the bumpers and spacer plates! It should have holes in the front for the original hood pins even if someone added a hood with hinges at a later date. If there are hinges, you could remove them to check out the paint behind them to see how it's painted in that area?
Re: A12 Identification [Re: Dave Watt] #638832
03/13/10 07:33 PM
03/13/10 07:33 PM
Connecticut
5126brl No more Offline
Connecticut
A good way to tell is the owner will have bad attitude and tell you "Do you know what this is?"
Hope this helps!
Re: A12 Identification [Re: 5126brl No more] #638833
03/13/10 08:49 PM
03/13/10 08:49 PM
Pugetroplis WA
Pugetroplis WA
Ok. I have my list. Should be enough clues if the fender tag happens to be missing. Thanks guys.
Re: A12 Identification [Re: RallyeMike] #638834
03/13/10 09:19 PM
03/13/10 09:19 PM
goodluck!
Re: A12 Identification [Re: 5126brl No more] #638835
03/13/10 10:40 PM
03/13/10 10:40 PM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
Hope this helps!
Seriously though, good luck. I hope everything works out for you. Hopefully we'll see some pictures soon....
Re: A12 Identification [Re: 69RTSE] #638836
03/13/10 11:35 PM
03/13/10 11:35 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
of all of the things mentioned the 3-speed wipers are most likely going to be there and posibly the 26" radiator opening. The fuel and return line, the oval filler neck hole, head rest, and for sure only a heater firewall, NO A/C firewall! If it has original fenders then the 383 callout emblem holes were never drilled, and the fender hood pad should have the hole enlarged for the front hood pins. No 3-speed wipers, 26" radiator or oval filler neck hole you better look closer IMO.....oh, and an A/C firewall and the claim it's an A12 then
Re: A12 Identification [Re: A12] #638837
03/14/10 08:50 AM
03/14/10 08:50 AM
sixbbl69 Offline
sixbbl69  Offline
k- frame
Re: A12 Identification [Re: sixbbl69] #638838
03/14/10 11:18 AM
03/14/10 11:18 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
k- frame
Why the k frame, whats diff?
Re: A12 Identification [Re: sixbbl69] #638839
03/14/10 11:19 AM
03/14/10 11:19 AM
Warrenton, VA
Warrenton, VA
It should have a title with an M in the VIN and a matching VIN. Unless you think it's a fake title and VIN, there's really no question. If it has an H in the VIN, it's kind of worthless as a possible A12 unless you have the original fender tag or some other documentation or proof that it was sold as an A12.
Re: A12 Identification [Re: RoadRunnerJD] #638840
03/14/10 11:25 AM
03/14/10 11:25 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
A few:
5th digit an "M"
DANA rear
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Page 1 of 3 1 2 3
