Page 1 of 3 1 2 3
440-1 vs B1 #637523
03/12/10 11:41 AM
03/12/10 11:41 AM
N. IL
tntmachine Offline OP
N. IL
Does the Indy -1 have a larger intake volume than a B1?
Re: 440-1 vs B1 [Re: tntmachine] #637524
03/12/10 11:50 AM
03/12/10 11:50 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No....Of course maybe that would depend on level of porting. IE box B1 VS fully ported -1 even then I am not sure the -1 would be higher.
Re: 440-1 vs B1 [Re: Al_Alguire] #637525
03/12/10 12:02 PM
03/12/10 12:02 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Don't the 440-1 has a longer port.
Re: 440-1 vs B1 [Re: supercomp] #637526
03/12/10 12:11 PM
03/12/10 12:11 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Having had my -1s next to Al's B1 - I can say absolutely not. The B1 is a huge port - especially when it is hogged out.
Re: 440-1 vs B1 [Re: Lil Demon] #637527
03/12/10 12:53 PM
03/12/10 12:53 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I dont know about port sizes, but there is no comparison in power potential.
Re: 440-1 vs B1 [Re: Bob_Coomer] #637528
03/12/10 01:03 PM
03/12/10 01:03 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
No dought about that. But Dave Koffel told me a B1 Orig. cnc ported had a 5.625 long 320cc intake port. I ask for my engine analyzer plus program.
Re: 440-1 vs B1 [Re: supercomp] #637529
03/12/10 01:07 PM
03/12/10 01:07 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I don't think the -1 is close outta the box. The B1's are usually 385 unported. That's what my flow sheets say.
Re: 440-1 vs B1 [Re: camastomcat] #637530
03/12/10 01:23 PM
03/12/10 01:23 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I thought he meant port volume cc's not cfm air flow.
Re: 440-1 vs B1 [Re: supercomp] #637531
03/12/10 01:52 PM
03/12/10 01:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Your results may vary. I can tell you mine are a bit bigger than that. I thought an Indy port was in the 320 range? Maybe I am mistaken.
Re: 440-1 vs B1 [Re: Al_Alguire] #637532
03/12/10 02:06 PM
03/12/10 02:06 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
My Intake CC after hand porting is 342cc. They are in line with the CNC 345's where it's my belief the 345 number in the head designation represents the CC of the intake after the CNC porting. I don't know what the B1's are.
Re: 440-1 vs B1 [Re: Al_Alguire] #637533
03/12/10 02:10 PM
03/12/10 02:10 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I'm only quoting Dave. I'll cc one when I pull one off. Jeff at mch ported these.
Re: 440-1 vs B1 [Re: Al_Alguire] #637534
03/12/10 02:15 PM
03/12/10 02:15 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
the -1s when fully worked over(like GregsDart has done to his) will give the original B1 a run for its money..but in the end the B1 will win. The -1 is a great flowing "max wedge" type head whereas the B1 was designed from a clean sheet of paper with maximum flow in mind.
Re: 440-1 vs B1 [Re: Al_Alguire] #637535
03/12/10 02:46 PM
03/12/10 02:46 PM
N. IL
N. IL
I am asking about the port volume, not CFM. The reason that I ask: I've been running a 493 cid -1 motor that has intake runner volumes of 327 cc's. I'm planning on putting together a bigger motor (572) with B1 heads. I saw a set of B1MC on here that stated the intake volume is 300cc. Since I don't have any B1 heads laying around to compare; I was wondering if the B1's have a shorter runner length than the Indy stuff?
Re: 440-1 vs B1 [Re: tntmachine] #637536
03/12/10 03:04 PM
03/12/10 03:04 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
yes
Re: 440-1 vs B1 [Re: tntmachine] #637537
03/12/10 03:26 PM
03/12/10 03:26 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Yeah, that stuff with the ti valves and T&D rocker gear is a great deal. I wish I had the money. You should meak better than 1000HP with that set up. I'm not sure about the 300cc coment, but Shady Dell should know. That's if we are talking about the same heads on racingjunk.
Re: 440-1 vs B1 [Re: camastomcat] #637538
03/12/10 04:08 PM
03/12/10 04:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
my indy are CNC 345s
Mopar Performance
Re: 440-1 vs B1 [Re: moparniac] #637539
03/12/10 04:14 PM
03/12/10 04:14 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Just my 2 cents worth, my -1 fully ported and polished , support 914 hp on a 578ci motor, if I had to do over again, I would go with b1 mc.I am maxxed out with no more room to grow, which means either sell heads for pennies on dollar, or let them sit on shelf if we want to step up. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: 440-1 vs B1 [Re: camastomcat] #637540
03/12/10 04:14 PM
03/12/10 04:14 PM
Gearbox Offline
Gearbox  Offline
Whats the deal on racing junk, the only set I see with T/D are Predators, do you have the Add Number of a B1 M/C set-up I may have missed.
Re: 440-1 vs B1 [Re: camastomcat] #637541
03/12/10 04:18 PM
03/12/10 04:18 PM
N. IL
N. IL
Yes, The heads that I'm refering to are on RJ.
Re: 440-1 vs B1 [Re: Gearbox] #637542
03/12/10 04:49 PM
03/12/10 04:49 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
They're on here 2nd page 1/2 way down. In the race parts section.
Page 1 of 3 1 2 3
