Painting Headers What to use? #637459
03/12/10 10:49 AM
03/12/10 10:49 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am sick of my headers always looking rusty and crusty! So, I am going to sandblast them and paint them. What should I use though to make sure they stay looking good?
Thanks!
RS23L7 4-Speed
Re: Painting Headers What to use? [Re: Mopar_Mike] #637460
03/12/10 10:59 AM
03/12/10 10:59 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
VHT Paint Flameproof
Re: Painting Headers What to use? [Re: DAMOPARS] #637461
03/12/10 11:07 AM
03/12/10 11:07 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used the VHT and it burned off quickly. I'm a BIG fan of charcoal grill paint. They sell it at home depot or lowes and it works. Painted an old set of heddmans and they looked good after 3 years of driving. I'll be heading to HD this weekend to pick up some for my new Super Comps
Coming soon!!!!
Re: Painting Headers What to use? [Re: DAMOPARS] #637462
03/12/10 11:09 AM
03/12/10 11:09 AM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Does this require any kind of primer or direct over steel?
Re: Painting Headers What to use? [Re: mymcodebee] #637463
03/12/10 11:14 AM
03/12/10 11:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I strip the factory paint (it's worthless) and then I wipe then down w/ brake clean then paint it on. Usuallly 3 light coats. Only problem is you can only get it in Black..well they might have red but who wants red headers?
Re: Painting Headers What to use? [Re: Mopar_Mike] #637464
03/12/10 11:18 AM
03/12/10 11:18 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i use eastwood manifold paint, the stuff they want you to brush on, on thin it and shot it out of my spray gun, blast headers, hang then i put on around 6-8 coats with that little pint, must be over bare steel or will flake off. works well
MOPAR OR NO CAR
Re: Painting Headers What to use? [Re: Mr.Yuck] #637465
03/12/10 11:20 AM
03/12/10 11:20 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I used the charcoal grill paint as well, but I have to tell you it didn't work either......but here's a bump as I know there are paint's out there that will work.
Re: Painting Headers What to use? [Re: DAMOPARS] #637466
03/12/10 11:27 AM
03/12/10 11:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ahhh just found this on the VHT paint. Maybe this is why mine didn't last.
On the Vehicle
• Paint must be completely dry before curing
• Run at idle for 10 minutes
• Cool for 20 minutes
• Run at idle for 20 minutes
• Run under normal operating conditions for
• 30 minutes
Off the Vehicle
• Heat to 250°F (121°C) for 30 minutes
• Cool for 30 minutes
• Heat to 400°F (204°C) for 30 minutes
• Heat to 650°F (343°C ) for 30 minutes
Not a chance a normal guy can run a heating cycle like that.
Re: Painting Headers What to use? [Re: Mopar_Mike] #637467
03/12/10 11:31 AM
03/12/10 11:31 AM
and after the cleaning/sanding/brake kleen should it be primed 1st (if so with what)
Re: Painting Headers What to use? [Re: RapidRobert] #637468
03/12/10 11:33 AM
03/12/10 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't think you need to prime it. If you did you'd have to have high temp primer too, so what's the point?
Re: Painting Headers What to use? [Re: Mr.Yuck] #637469
03/12/10 11:38 AM
03/12/10 11:38 AM
the point would be to achieve a paint that would last which is what we are trying to figure out here
Re: Painting Headers What to use? [Re: RapidRobert] #637470
03/12/10 11:40 AM
03/12/10 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
most cans of hightemp paint I have read say apply to bare metal...
Re: Painting Headers What to use? [Re: Mr.Yuck] #637471
03/12/10 11:44 AM
03/12/10 11:44 AM
Clinton Twp. Michigan
coronet1966d Offline
VHT wants you to use there white high temp primer
Re: Painting Headers What to use? [Re: Mr.Yuck] #637472
03/12/10 11:47 AM
03/12/10 11:47 AM
yeah that is what I was wondering as I've done very little painting and I did not know if the same (painting) basics applied to headers just like car panels and since it sounds problematic when I get to that point I want to increase my odds of it not burning off. Alright NO primer. Now on to the best paint/technique and I think some sort of heat curing is the key. There is a plater close by, would that be doable & if so what metal?
Re: Painting Headers What to use? [Re: RapidRobert] #637473
03/12/10 11:49 AM
03/12/10 11:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Not sure what's local to you but there are companies out there that will jet coat your headers. Not sure how much it costs.
Re: Painting Headers What to use? [Re: Mr.Yuck] #637474
03/12/10 11:54 AM
03/12/10 11:54 AM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
My local coating shop wanted about $400 to coat a set of BB headers.
Re: Painting Headers What to use? [Re: Mr.Yuck] #637475
03/12/10 11:57 AM
03/12/10 11:57 AM
Lincoln plating (now Lincoln Industries) does plating for Speedway motors and Harley Davidson an they do chrome gold and nickel. I'll have to call them & see if they will do a piece for an off the street customer, how much and what other metals they offer and what they might recommend. I'm not a painter but I think some kind of heat curing is going to be required for a paint to last. EDIT unless maybe a specialty aircraft type which would be $$$ but if that's what it takes
Re: Painting Headers What to use? [Re: RapidRobert] #637476
03/12/10 12:07 PM
03/12/10 12:07 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
What ever happened to the
"Aluma Coat" BlackJack offered in the 80s? They would spray their cheap headers with molten aluminum. The finish was a very course abrasive aluminum colored coating. It was durable and not expensive.
Keep old mopars alive.
Re: Painting Headers What to use? [Re: RapidRobert] #637477
03/12/10 12:08 PM
03/12/10 12:08 PM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: Painting Headers What to use? [Re: MRHWS] #637478
03/13/10 09:56 AM
03/13/10 09:56 AM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
www.techlinecoatings.com you can buy the same type coatings that jet-hot uses and apply them yourself. Save a lot of money, check them out.
