Painting Headers What to use?
#637459
03/12/10 10:49 AM
03/12/10 10:49 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am sick of my headers always looking rusty and crusty! So, I am going to sandblast them and paint them. What should I use though to make sure they stay looking good?
Thanks!
RS23L7 4-Speed
Re: Painting Headers What to use?
[Re: Mopar_Mike]
#637460
03/12/10 10:59 AM
03/12/10 10:59 AM
Posts: 4,978 VA
DAMOPARS
VA
[Re: mymcodebee]
#637463
03/12/10 11:14 AM
03/12/10 11:14 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Does this require any kind of primer or direct over steel?
I strip the factory paint (it's worthless) and then I wipe then down w/ brake clean then paint it on. Usuallly 3 light coats. Only problem is you can only get it in Black..well they might have red but who wants red headers?
[Re: DAMOPARS]
#637466
03/12/10 11:27 AM
03/12/10 11:27 AM
Mr.Yuck
Brookeville, Md
VHT Paint Flameproof
ahhh just found this on the VHT paint. Maybe this is why mine didn't last. On the Vehicle
• Paint must be completely dry before curing • Run at idle for 10 minutes • Cool for 20 minutes • Run at idle for 20 minutes • Cool for 20 minutes • Run under normal operating conditions for • 30 minutes Off the Vehicle
• Paint must be completely dry before curing • Heat to 250°F (121°C) for 30 minutes • Cool for 30 minutes • Heat to 400°F (204°C) for 30 minutes • Cool for 30 minutes • Heat to 650°F (343°C ) for 30 minutes
Not a chance a normal guy can run a heating cycle like that.
[Re: Mopar_Mike]
#637467
03/12/10 11:31 AM
03/12/10 11:31 AM
RapidRobert
and after the cleaning/sanding/brake kleen should it be primed 1st (if so with what)
[Re: RapidRobert]
#637468
03/12/10 11:33 AM
03/12/10 11:33 AM
Mr.Yuck
Brookeville, Md
I don't think you need to prime it. If you did you'd have to have high temp primer too, so what's the point?
[Re: RapidRobert]
#637470
03/12/10 11:40 AM
03/12/10 11:40 AM
Mr.Yuck
Brookeville, Md
the point would be to achieve a paint that would last which is what we are trying to figure out here
most cans of hightemp paint I have read say apply to bare metal...
[Re: Mr.Yuck]
#637474
03/12/10 11:54 AM
03/12/10 11:54 AM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
Not sure what's local to you but there are companies out there that will jet coat your headers. Not sure how much it costs.
My local coating shop wanted about $400 to coat a set of BB headers.
[Re: Mr.Yuck]
#637475
03/12/10 11:57 AM
03/12/10 11:57 AM
RapidRobert
Lincoln plating (now Lincoln Industries) does plating for Speedway motors and Harley Davidson an they do chrome gold and nickel. I'll have to call them & see if they will do a piece for an off the street customer, how much and what other metals they offer and what they might recommend. I'm not a painter but I think some kind of heat curing is going to be required for a paint to last. EDIT unless maybe a specialty aircraft type which would be $$$ but if that's what it takes
[Re: RapidRobert]
#637476
03/12/10 12:07 PM
03/12/10 12:07 PM
Posts: 4,776 Holland MI Ottawa
2boltmain
Holland MI Ottawa
What ever happened to the "Aluma Coat" BlackJack offered in the 80s? They would spray their cheap headers with molten aluminum. The finish was a very course abrasive aluminum colored coating. It was durable and not expensive.
Keep old mopars alive.
