stealth vs 906 Heads #637376
03/12/10 09:56 AM
03/12/10 09:56 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I am currently having my engine built and was curious is changing my 906 Heads worth it for my application. I have the voodo cam 60301 and it's bored .030. I have the HP manifolds as well with a Edl performer intake and 750 holley. I plan to drive mine more on the streets with the occasional horse play and tire burn out. I ask because the guy doing my Machine work is charging around 3 cenos for the 3 angle valve job and all. And if I had the 906 ported a little would that be equal performance to the stealths? Just curious.
Re: stealth vs 906 Heads [Re: roy2345] #637377
03/12/10 10:04 AM
03/12/10 10:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well since you are using logs and a Performer intake and not an RPM I see no reason to port or buy the stealth heads. That's not much of a cam so I think your 906 heads and current work will be fine. You can run 12's with stock 906 heads on a very mild 440, so I think you'll be fine.
Coming soon!!!!
Re: stealth vs 906 Heads [Re: Mr.Yuck] #637378
03/12/10 10:09 AM
03/12/10 10:09 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
oops its the lunati 60302 cam. So I would never really even tap into that level of performance with my cam etc to even notice a port job on my 906 heads?
Re: stealth vs 906 Heads [Re: roy2345] #637379
03/12/10 10:16 AM
03/12/10 10:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
porting is always a good idea, but since you are using non-performace exhaust and an intake not much better than stock I doubut you will see the advantage. If you went w/ headers, RPM or S/D intake and 3.91's you'd see the difference. I ran 12.90's w/ stock 906's on mild 440. The valve job and angle cut will help, also if you plan on adding to the build later the porting will help. The problem is the cost. It's probably going to be cheaper just to buy the stealth heads in the long run. I mean you reach $800 pretty quick when you start grinding, plus it already has 2.14/1.81 valves. 906's have 2.08/1.74 valves. If this is a car you just want to beat around the street with I'd just stick with your fresh 906's.
Re: stealth vs 906 Heads [Re: Mr.Yuck] #637380
03/12/10 01:39 PM
03/12/10 01:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stealths are going to flow more than a mildly tweaked set of 906's. I agree with swingin, your combo is too mild to benefit much from the stealths. I would leave your heads bone stock for now, don't invest anything into them. Then later on down the road if you choose to step up to more cam like the 60304, rpm intake, 850 carb, add a set of headers, then you'll be able to put the extra flow of aftermarket heads to use.
Re: stealth vs 906 Heads [Re: DaytonaTurbo] #637381
03/12/10 03:54 PM
03/12/10 03:54 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Thanks fellas! Yall have answered my questions. I'll hang in there with the 906's. My aluminum intake isn't much better performance then my stock intake?
Re: stealth vs 906 Heads [Re: roy2345] #637382
03/12/10 04:31 PM
03/12/10 04:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If it's a "Perfomer" it's better but not by much. The Performer RPM is the good one.
Re: stealth vs 906 Heads [Re: roy2345] #637383
03/12/10 05:09 PM
03/12/10 05:09 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Do you mean C notes? a.k.a. $100 bills?
Yes, stay with the stock heads for now. And the Performer RPM intake is the high performance one..
Re: stealth vs 906 Heads [Re: HemiDave] #637384
03/12/10 05:13 PM
03/12/10 05:13 PM
Manitoba, Canada
Manitoba, Canada
But basically a waste with stock flowing heads. In his case the intake manifold is not the bottleneck.
Re: stealth vs 906 Heads [Re: DaytonaTurbo] #637385
03/12/10 05:14 PM
03/12/10 05:14 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
But if he wants to start 'somewhere'..that or a nice used LD340...
Re: stealth vs 906 Heads [Re: HemiDave] #637386
03/12/10 05:21 PM
03/12/10 05:21 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
That an awful lot of machine work to fit a small block intake to a big block there is better options..
Re: stealth vs 906 Heads [Re: QuickBpBp] #637387
03/12/10 05:25 PM
03/12/10 05:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
CH4B - 440 goooood intake
Re: stealth vs 906 Heads [Re: Mr.Yuck] #637388
03/12/10 10:46 PM
03/12/10 10:46 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
sorry it's the rpm performer intake for the 440....idle to 5600 rpm
Re: stealth vs 906 Heads [Re: roy2345] #637389
03/13/10 09:18 AM
03/13/10 09:18 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Get stealth heads before spending any money on iron.
First it will be $300 for valve job and $200 for guides and $200 for new valves (a must IMO) and $100 for new valve springs + any port work and you still have 40 year old crack prone heads. You should have new retainers and keepers too
Eddy heads are more but worth it as the stealths are well "Chinese".
Re: stealth vs 906 Heads [Re: Dodgem] #637390
03/14/10 08:29 PM
03/14/10 08:29 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Why would the 906's crack? They were fine when the engine was torn down other then valve guide seals.
Re: stealth vs 906 Heads [Re: roy2345] #637391
03/14/10 09:06 PM
03/14/10 09:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cast iron has a tendency to get brittle with age and heat cycles.
Re: stealth vs 906 Heads [Re: Dodgem] #637392
03/14/10 11:08 PM
03/14/10 11:08 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Especially after you grind the snot out of them doing port work.
Re: stealth vs 906 Heads [Re: '72CudaRacer] #637393
03/14/10 11:33 PM
03/14/10 11:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do run ported 906's but if the Stealth heads had been out when I built my 440 I would have bought them. That said the 906's are holding up fine but I feel I could go faster with a nice aluminum head. Ron
Re: stealth vs 906 Heads [Re: '72CudaRacer] #637394
03/15/10 02:11 PM
03/15/10 02:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: stealth vs 906 Heads [Re: Dodgem] #637395
03/15/10 05:25 PM
03/15/10 05:25 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
All of my ported iron heads have cracked sooner or later. Usually right below the center exhaust ports. Those two exhaust valves are close together and get HOT!!! If you going to be in the hobby for a while, get the stealths. They will grow with you as your need for performance does (it's a sickness, just ask my wife).
