Re: stealth vs 906 Heads
[Re: Mr.Yuck]
#637380
03/12/10 01:39 PM
03/12/10 01:39 PM
DaytonaTurbo
Manitoba, Canada
Stealths are going to flow more than a mildly tweaked set of 906's. I agree with swingin, your combo is too mild to benefit much from the stealths. I would leave your heads bone stock for now, don't invest anything into them. Then later on down the road if you choose to step up to more cam like the 60304, rpm intake, 850 carb, add a set of headers, then you'll be able to put the extra flow of aftermarket heads to use.
[Re: roy2345]
#637382
03/12/10 04:31 PM
03/12/10 04:31 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks fellas! Yall have answered my questions. I'll hang in there with the 906's. My aluminum intake isn't much better performance then my stock intake?
If it's a "Perfomer" it's better but not by much. The Performer RPM is the good one.
[Re: roy2345]
#637383
03/12/10 05:09 PM
03/12/10 05:09 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
because the guy doing my Machine work is charging around 3 cenos for the 3 angle valve job
Do you mean C notes? a.k.a. $100 bills?
Yes, stay with the stock heads for now. And the Performer RPM intake is the high performance one..
[Re: HemiDave]
#637384
03/12/10 05:13 PM
03/12/10 05:13 PM
DaytonaTurbo
Manitoba, Canada
But basically a waste with stock flowing heads. In his case the intake manifold is not the bottleneck.
[Re: HemiDave]
#637386
03/12/10 05:21 PM
03/12/10 05:21 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
But if he wants to start 'somewhere'..that or a nice used LD340...
That an awful lot of machine work to fit a small block intake to a big block there is better options..
[Re: QuickBpBp]
#637387
03/12/10 05:25 PM
03/12/10 05:25 PM
Mr.Yuck
Brookeville, Md
CH4B - 440 goooood intake
[Re: Dodgem]
#637392
03/14/10 11:08 PM
03/14/10 11:08 PM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Cast iron has a tendency to get brittle with age and heat cycles.
Especially after you grind the snot out of them doing port work.
[Re: '72CudaRacer]
#637394
03/15/10 02:11 PM
03/15/10 02:11 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
