Re: Main bearing clearance problem
[Re: '72CudaRacer]
#635903
03/10/10 06:58 PM
03/10/10 06:58 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
On a street engine with a hyd cam I'd run what you have.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: jamesc]
#635904
03/10/10 07:04 PM
03/10/10 07:04 PM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
what are you using to determine these clearances?
A micrometer, a dial bore gauge and a calculater. I've even got my machinist to come over last nite and check it. Still tight.
[Re: DaveDudek]
#635906
03/10/10 07:06 PM
03/10/10 07:06 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
.002-.003 is in spec. I'd say your fine. tighter tolerances mean you can run a lighter weight oil. I bet today's new engines run tighter then that!
you could have an error of .0001 - .0002 if there was a spec of dust or something when you measured.
**Photobucket sucks**
[Re: '72CudaRacer]
#635908
03/10/10 09:26 PM
03/10/10 09:26 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Brian,
What were the actual crank main dimensions?
RIP Monte Smith
[Re: CompWedgeEngines]
#635911
03/10/10 11:05 PM
03/10/10 11:05 PM
'72CudaRacer
Mooresburg, Tn
Brian,
Todd, I been tring to call you all day. No answer, mail box full. again. Crank front to rear; 2.7498 2.7499 2.7499 2.7496 2.7496
Thanks, Brian
[Re: '72CudaRacer]
#635912
03/10/10 11:43 PM
03/10/10 11:43 PM
CompWedgeEngines
Syracuse,NY
Yes, phone has been a little silly lately. It reached 40 degrees and now everyone thinks their engine should be done...lol
RIP Monte Smith
