Demon running hot #63444
05/25/08 08:40 PM
05/25/08 08:40 PM
Marine Corps Base Hawaii
DemonKyle Offline OP
USMC LCPL
USMC LCPL
How do you tell if the clutch fan is bad? My car overheats when idling in traffic. Gets to about 220* or so. I know that the water pump is good and the cooling system is clean. It cools down as soon as it gets out of traffic and gets some air flow into the radiator. Also, the radiator has been cleaned and recored so I have ruled that out. I'm almost 100% sure its either the clutch fan or radiator cap but the cap is also somewhat brand new.
Any ideas?
-Kyle
Re: Demon running hot [Re: DemonKyle] #63445
05/25/08 08:52 PM
05/25/08 08:52 PM
easy.
if it turns easily while the engine is hot. its shot. fan belt tight? pully grooves arn't to "shiny"?
Re: Demon running hot [Re: DemonKyle] #63446
05/25/08 08:53 PM
05/25/08 08:53 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
See link below for an old fan clutch discussion. Look down about 3/4's of the page at the test John Kunkle describes.
Ron
https://board.moparts.org/ubbthreads/show...rue#Post3452425
Re: Demon running hot #63447
05/25/08 08:53 PM
05/25/08 08:53 PM
USMC LCPL
USMC LCPL
No everything is tight
Re: Demon running hot [Re: DemonKyle] #63448
05/25/08 09:01 PM
05/25/08 09:01 PM
Kirkland, Washington
Pacnorthcuda Offline
Cap only determines the pressure at which it pukes, nothing to do with temp.
Do you have corrosion/scale in the rad? That could easily compromise its performance.
Re: Demon running hot #63449
05/25/08 09:24 PM
05/25/08 09:24 PM
USMC LCPL
USMC LCPL
Doesn't spin easily and also passed the tape test that Kunkel mentioned. Now I'm completely lost.
Re: Demon running hot [Re: DemonKyle] #63450
05/25/08 09:48 PM
05/25/08 09:48 PM
i had thermostats that never completely opened before. matter-o-fact, i once got 2 in a row that didn't.
Re: Demon running hot #63451
05/25/08 10:05 PM
05/25/08 10:05 PM
USMC LCPL
USMC LCPL
Thermostat is a 160 but opens up completely. Could the lower temp be a problem?
Re: Demon running hot [Re: DemonKyle] #63452
05/25/08 10:11 PM
05/25/08 10:11 PM
to much coolant mix, air in the system, inaccurate gauge, bad waterpump, crappy rad rebuild. lotsa variables
at play here. fan blades should be 1/2 in 1/2 outta the shrowd.
Re: Demon running hot [Re: DemonKyle] #63453
05/25/08 10:44 PM
05/25/08 10:44 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
DemonKyle -
Does the system build up presure? The should be hoses hard to compress. Does the fan blow a ton of air when the engine is revved? It should.
Ron
Re: Demon running hot #63454
05/25/08 11:03 PM
05/25/08 11:03 PM
USMC LCPL
USMC LCPL
50-50 Prestone mix, brand new gauge from Auto Meter w/ sending unit, brand new pump and radiator was cleaned and recored.
Re: Demon running hot [Re: Ronnman] #63455
05/25/08 11:05 PM
05/25/08 11:05 PM
USMC LCPL
USMC LCPL
DemonKyle -
Ron
Builds pressure just fine and fan blows plenty of air.
Also now that I think about should I worry about the fact that I can completely depress the top hose when the car is cold. Its as if there is no water in the hose but I can hear it suctioning however when I let go of the hose
Re: Demon running hot [Re: DemonKyle] #63456
05/25/08 11:07 PM
05/25/08 11:07 PM
runnin' a shrowd (sp?)? check for a stubborn air pocket?
7deg celcius here and tornado warnings...great
Re: Demon running hot #63457
05/25/08 11:09 PM
05/25/08 11:09 PM
USMC LCPL
USMC LCPL
Stock fan and shroud.
Re: Demon running hot [Re: DemonKyle] #63458
05/25/08 11:13 PM
05/25/08 11:13 PM
well that just about covers all the bases.
check for a air pocket. force the upper rad hose below the level
of the top tank on the rad. make sure to do the same with the heater hoses. then top it up. also, make sure the
resevoir is at the full mark. or.. your new engine may just like going to 220deg when idling.
Re: Demon running hot #63459
05/25/08 11:18 PM
05/25/08 11:18 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Hell, mine normally runs 210-220...you're worried??
Sorry, I can't help ya much -- I've been trying to get mine to cool down for 3 years. I gave up...
Re: Demon running hot [Re: Hotwheelsjr] #63460
05/25/08 11:22 PM
05/25/08 11:22 PM
USMC LCPL
USMC LCPL
I should also add that it has a bottle of Royal Purple cooler added into it.
Re: Demon running hot [Re: Hotwheelsjr] #63461
05/25/08 11:24 PM
05/25/08 11:24 PM
USMC LCPL
USMC LCPL
Well hell mike
Theres a difference between our weather don't ya think. This is happening in low 70's night time crusing. Not 90* arizona heat.
But hey at least its a dry heat
Re: Demon running hot [Re: DemonKyle] #63462
05/26/08 12:29 PM
05/26/08 12:29 PM
littlestown pa
dustpan man Offline
dustpan man  Offline
littlestown pa
did you put a different engine in it and kep the old rad in it
Re: Demon running hot [Re: dustpan man] #63463
05/26/08 10:37 PM
05/26/08 10:37 PM
USMC LCPL
USMC LCPL
Yea it has a rebuilt 360. Nothing big. Old radiator was the 22" stock 318 one. Don't really see it not being able to supply enough cool water tho
