Re: Demon running hot
[Re: DemonKyle]
#63445
05/25/08 08:52 PM
05/25/08 08:52 PM
easy. if it turns easily while the engine is hot. its shot. fan belt tight? pully grooves arn't to "shiny"?
[Re: DemonKyle]
#63450
05/25/08 09:48 PM
05/25/08 09:48 PM
i had thermostats that never completely opened before. matter-o-fact, i once got 2 in a row that didn't.
[Re: DemonKyle]
#63452
05/25/08 10:11 PM
05/25/08 10:11 PM
to much coolant mix, air in the system, inaccurate gauge, bad waterpump, crappy rad rebuild. lotsa variables at play here. fan blades should be 1/2 in 1/2 outta the shrowd.
#63454
05/25/08 11:03 PM
05/25/08 11:03 PM
Posts: 3,312 Marine Corps Base Hawaii
DemonKyle
USMC LCPL
USMC LCPL
50-50 Prestone mix, brand new gauge from Auto Meter w/ sending unit, brand new pump and radiator was cleaned and recored.
[Re: Ronnman]
#63455
05/25/08 11:05 PM
05/25/08 11:05 PM
DemonKyle
USMC LCPL
USMC LCPL
DemonKyle - Does the system build up presure? The should be hoses hard to compress. Does the fan blow a ton of air when the engine is revved? It should. Ron
Builds pressure just fine and fan blows plenty of air.
Also now that I think about should I worry about the fact that I can completely depress the top hose when the car is cold. Its as if there is no water in the hose but I can hear it suctioning however when I let go of the hose
[Re: DemonKyle]
#63456
05/25/08 11:07 PM
05/25/08 11:07 PM
runnin' a shrowd (sp?)? check for a stubborn air pocket? 7deg celcius here and tornado warnings...great
[Re: DemonKyle]
#63458
05/25/08 11:13 PM
05/25/08 11:13 PM
well that just about covers all the bases. check for a air pocket. force the upper rad hose below the level of the top tank on the rad. make sure to do the same with the heater hoses. then top it up. also, make sure the resevoir is at the full mark. or.. your new engine may just like going to 220deg when idling.
[Re: Hotwheelsjr]
#63461
05/25/08 11:24 PM
05/25/08 11:24 PM
DemonKyle
USMC LCPL
USMC LCPL
Hell, mine normally runs 210-220...you're worried?
Well hell mike Theres a difference between our weather don't ya think. This is happening in low 70's night time crusing. Not 90* arizona heat. But hey at least its a dry heat
[Re: dustpan man]
#63463
05/26/08 10:37 PM
05/26/08 10:37 PM
DemonKyle
USMC LCPL
USMC LCPL
did you put a different engine in it and kep the old rad in it
Yea it has a rebuilt 360. Nothing big. Old radiator was the 22" stock 318 one. Don't really see it not being able to supply enough cool water tho
