Undersized timing chain set for a SB mopar #630437
03/04/10 03:12 PM
03/04/10 03:12 PM
412 SB Duster Offline OP
Does anyone make a undersized timing chain set for a SB mopar?
Or is a tensioner my only choice.
Al
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #630438
03/04/10 04:03 PM
03/04/10 04:03 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
I got an undersized Rollmaster for mine 3-4-5 years ago.
1970 Charger R/T 1970 Dart Swinger 340/4spd
Re: Undersized timing chain set for a SB mopar [Re: Bill_G] #630439
03/04/10 06:32 PM
03/04/10 06:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Al....put a gear drive on it and be done with it, Milidon makes a real nice one
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Undersized timing chain set for a SB mopar [Re: B3422W5] #630440
03/04/10 07:48 PM
03/04/10 07:48 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
small block magnums have one. i used it on my 408. no problems that i know of.
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Undersized timing chain set for a SB mopar [Re: wldtm] #630441
03/05/10 12:08 AM
03/05/10 12:08 AM
IN
ahy Offline
ahy  Offline
IN
I run a .010 under Cloyes on a BB. They probably have them for SB also, but I'd be happy to run a tensioner. I think its a better setup and avoids the trial and error (in my case) of finding the exact right length chain.
Re: Undersized timing chain set for a SB mopar [Re: B3422W5] #630442
03/05/10 12:32 AM
03/05/10 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
plus you wont be changing chains all the time,
I run a KB gear set up on both of my SB... both of
them have been on for a long time(more so with my
W-2)
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2543959
08/31/18 07:01 PM
08/31/18 07:01 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
how come will a gear drive setup compensate for a block thats been align bored?
I have this same problem with a 340 in which a new timing chain fits with a lot of slack.
This is not a race engine, but a restoration build, and even though I could use a chain tensioner, it really doesnt give me peace of mind....specially if the new chain has so much slack on a fresh build....i fear it might pound the tensioner till failure. not good.
I also read that those Milodon gear drives are the "quiet" type. Are they really quiet as they advertise them to be?
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2543995
08/31/18 09:32 PM
08/31/18 09:32 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Al
. I had a 408 that had lots of work done to the mains. That work moved the crankshaft up. I opted for a tensioner it was the first time I had ran one I beat the snot out of that motor forever it performed flawlessly.. now I will not assemble a small block Dodge with a chain without using a tensioner.. this was my experience
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2544035
08/31/18 11:23 PM
08/31/18 11:23 PM
New York, USA
Chargerfan68 Offline
New York, USA
The way im thinking about this in my miind, i like the idea of a tensioner, but i still think a properly sized chain will keep cam timing in sync with crank /piston position. I would think the flexing of the tensioner would allow for movement on decelleration compared to acceleration. I could be wrong, but this seems possible.
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2544196
09/01/18 11:54 AM
09/01/18 11:54 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
Gear drive for a normal cam MUST have an idler, or the cam would turn backward.
Boffin Emeritus
Re: Undersized timing chain set for a SB mopar [Re: polyspheric] #2544223
09/01/18 12:49 PM
09/01/18 12:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes my gear drive has a idler gear on it.. thats
the part thats adjustable(it can move some to
take up for a crank being turned down).. love that
gear drive set up(this is a single idler gear set
up) unlike the dual gear this is quiet on the street
EDIT
I have a tensioner on my 416 with a chain.. I was
concerned about the chain on the tensioner and how it
would wear but I have had it apart a few times and
that doesnt seem to be a issue.. the most that can
happen is the chain will wear down enough so the
tensioner will spread out the load and the chain
will be on more surface area but it hasnt got down
that far.. yet
wave
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2544347
09/01/18 06:14 PM
09/01/18 06:14 PM
New York
New York
I read some scary comments about the "dual floating idler" drive, sounds like the self-centering effect causes violent changes in lash and tooth contact.
Anyone make a chain drive with an adjustable (not spring loaded) tensioner to avoid the slack loop on decel?
Boffin Emeritus
Re: Undersized timing chain set for a SB mopar [Re: polyspheric] #2544380
09/01/18 08:12 PM
09/01/18 08:12 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
chances is if he's got plenty of p2v what happens on decel is not that important.. unless he is talking about. A ton lash in the chain.. if you can take the whip out of the backside of the chain.. usually it will not stretch very much.. most of this stuff is not rocket science nor does it need to be that complicated.. put it together and have fun
Re: Undersized timing chain set for a SB mopar [Re: 412 SB Duster] #2544713
09/02/18 04:17 PM
09/02/18 04:17 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
thanks for the replies guys_°
