Re: Undersized timing chain set for a SB mopar
[Re: 412 SB Duster]
#630438
03/04/10 04:03 PM
03/04/10 04:03 PM
Posts: 323 Maryland
Bill_G
Maryland
I got an undersized Rollmaster for mine 3-4-5 years ago.
1970 Charger R/T
1970 Dart Swinger 340/4spd
[Re: B3422W5]
#630440
03/04/10 07:48 PM
03/04/10 07:48 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
small block magnums have one. i used it on my 408. no problems that i know of. justin ![](/ubbthreads/images/graemlins/thumbs.gif)
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: B3422W5]
#630442
03/05/10 12:32 AM
03/05/10 12:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Al....put a gear drive on it and be done with it, Milidon makes a real nice one
plus you wont be changing chains all the time, I run a KB gear set up on both of my SB... both of them have been on for a long time(more so with my W-2) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 412 SB Duster]
#2543995
08/31/18 09:32 PM
08/31/18 09:32 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Does anyone make a undersized timing chain set for a SB mopar?
Or is a tensioner my only choice.
Thanks Al . I had a 408 that had lots of work done to the mains. That work moved the crankshaft up. I opted for a tensioner it was the first time I had ran one I beat the snot out of that motor forever it performed flawlessly.. now I will not assemble a small block Dodge with a chain without using a tensioner.. this was my experience
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 412 SB Duster]
#2544035
08/31/18 11:23 PM
08/31/18 11:23 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
The way im thinking about this in my miind, i like the idea of a tensioner, but i still think a properly sized chain will keep cam timing in sync with crank /piston position. I would think the flexing of the tensioner would allow for movement on decelleration compared to acceleration. I could be wrong, but this seems possible.
[Re: 412 SB Duster]
#2544196
09/01/18 11:54 AM
09/01/18 11:54 AM
Posts: 4,213 New York
polyspheric
New York
Gear drive for a normal cam MUST have an idler, or the cam would turn backward.
Boffin Emeritus
[Re: polyspheric]
#2544223
09/01/18 12:49 PM
09/01/18 12:49 PM
MR_P_BODY
Yes my gear drive has a idler gear on it.. thats the part thats adjustable(it can move some to take up for a crank being turned down).. love that gear drive set up(this is a single idler gear set up) unlike the dual gear this is quiet on the street EDIT I have a tensioner on my 416 with a chain.. I was concerned about the chain on the tensioner and how it would wear but I have had it apart a few times and that doesnt seem to be a issue.. the most that can happen is the chain will wear down enough so the tensioner will spread out the load and the chain will be on more surface area but it hasnt got down that far.. yet
[Re: 412 SB Duster]
#2544347
09/01/18 06:14 PM
09/01/18 06:14 PM
polyspheric
New York
I read some scary comments about the "dual floating idler" drive, sounds like the self-centering effect causes violent changes in lash and tooth contact. Anyone make a chain drive with an adjustable (not spring loaded) tensioner to avoid the slack loop on decel?
Boffin Emeritus
[Re: polyspheric]
#2544380
09/01/18 08:12 PM
09/01/18 08:12 PM
WHITEDART
bean town ....Ca
I read some scary comments about the "dual floating idler" drive, sounds like the self-centering effect causes violent changes in lash and tooth contact. Anyone make a chain drive with an adjustable (not spring loaded) tensioner to avoid the slack loop on decel? chances is if he's got plenty of p2v what happens on decel is not that important.. unless he is talking about. A ton lash in the chain.. if you can take the whip out of the backside of the chain.. usually it will not stretch very much.. most of this stuff is not rocket science nor does it need to be that complicated.. put it together and have fun
