Lug nut torque spec when using Weld wheels?
#630342
03/04/10 11:14 AM
03/04/10 11:14 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
What is the proper spec for the lugs when using wheels like Weld Rod-Lites, Pro-Star, or Drag-Lites? The have the 2 halves with the free floating aluminum center piece sandwiched in there. I have overtorqued them in the past and squashed the holes, so I want to get it right this time.
Personally I hate the idea of that aluminum piece being loose in there until it is tightened since it is never guaranteed to be in the center when you tighten it. Seem like a terrible balance issue waiting to happen.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Lug nut torque spec when using Weld wheels?
[Re: 67Charger]
#630343
03/04/10 11:19 AM
03/04/10 11:19 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Had the same issues, got better washers that won't deform. The thin ones are junk. I use 100 ft lbs on my 1/2 inchers, more on the bigger ones I now have on the back.
[Re: gregsdart]
#630344
03/04/10 11:22 AM
03/04/10 11:22 AM
67Charger
Erda, UT
Where do you find good ones? I used the regular included (thin) ones first which messed up the holes, then I switched to what I thought were nice thick larger o.d. ones made by Gorrila, but after I tightened them once they stuck to the lug nut and will neither spin nor come back off, so it drags against the face of the wheel as they get taken on and off. I just bought a new set of WELD lugs and washers hoping the quality will be better.
[Re: gregsdart]
#630349
03/04/10 10:11 PM
03/04/10 10:11 PM
Posts: 16,929 NC
440Jim
NC
I don't know the best answer, but that is what I used with 1/2" studs. I now have 5/8" studs.
This is a good question. Use a torque wrench, and retighten them after the first pass. Then they should stay tight. Every time I rotate wheels or take them off for any reason, I retighten after the first run. Loose lugs nuts are bad news...
