Lug nut torque spec when using Weld wheels? #630342
03/04/10 11:14 AM
03/04/10 11:14 AM
Erda, UT
67Charger Offline OP
Erda, UT
What is the proper spec for the lugs when using wheels like Weld Rod-Lites, Pro-Star, or Drag-Lites? The have the 2 halves with the free floating aluminum center piece sandwiched in there. I have overtorqued them in the past and squashed the holes, so I want to get it right this time.
Personally I hate the idea of that aluminum piece being loose in there until it is tightened since it is never guaranteed to be in the center when you tighten it. Seem like a terrible balance issue waiting to happen.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Lug nut torque spec when using Weld wheels? [Re: 67Charger] #630343
03/04/10 11:19 AM
03/04/10 11:19 AM
gregsdart Offline
gregsdart  Offline
Had the same issues, got better washers that won't deform. The thin ones are junk.
I use 100 ft lbs on my 1/2 inchers, more on the bigger ones I now have on the back.
Re: Lug nut torque spec when using Weld wheels? [Re: gregsdart] #630344
03/04/10 11:22 AM
03/04/10 11:22 AM
Erda, UT
Erda, UT
Where do you find good ones? I used the regular included (thin) ones first which messed up the holes, then I switched to what I thought were nice thick larger o.d. ones made by Gorrila, but after I tightened them once they stuck to the lug nut and will neither spin nor come back off, so it drags against the face of the wheel as they get taken on and off. I just bought a new set of WELD lugs and washers hoping the quality will be better.
Re: Lug nut torque spec when using Weld wheels? [Re: 67Charger] #630345
03/04/10 11:35 AM
03/04/10 11:35 AM
West Australia Australia
N
n2ofish Offline
n2ofish  Offline
N
I do my 1/2" to 65ftlbs and 7/16" to 55. I got these from either Weld or ARP.
Aussie 70 VG Valiant coupe,10.888 @ 122.44 so far
Re: Lug nut torque spec when using Weld wheels? [Re: n2ofish] #630346
03/04/10 11:55 AM
03/04/10 11:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Foot pounds or Newton Meters I do 1/2" studs to 100 ft/lbs. My 5/8" studs go to 120 ft/lbs.
Re: Lug nut torque spec when using Weld wheels? [Re: Al_Alguire] #630347
03/04/10 04:56 PM
03/04/10 04:56 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
Mine are 1/2" studs and torqued to 75 ft/lbs.I think that's what Weld recommends but not 100% sure. I retorque and check before i go racing and they usually stay where they are and i use Mc Guard nuts/washers they're a good thick washer and never stick.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Lug nut torque spec when using Weld wheels? [Re: 67Charger] #630348
03/04/10 10:06 PM
03/04/10 10:06 PM
North Branch, MI, USA
notchbackcuda Offline
I've always torqued mine to 65 lbs. (pro stars) but I just googled it and it looks like the torque should be more like 90 on a 1/2 inch grade 5 fine thread. If anything, wheel studs should be at least grade 5, right?
Re: Lug nut torque spec when using Weld wheels? [Re: gregsdart] #630349
03/04/10 10:11 PM
03/04/10 10:11 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know the best answer, but that is what I used with 1/2" studs. I now have 5/8" studs.
This is a good question. Use a torque wrench, and retighten them after the first pass. Then they should stay tight. Every time I rotate wheels or take them off for any reason, I retighten after the first run. Loose lugs nuts are bad news...
