Re: Mini Tubbing '71 B body
[Re: whitemtnelf]
#629704
03/03/10 02:41 PM
03/03/10 02:41 PM
Posts: 30 Oakbank, Manitoba, Canada
64 Savoy
Hi,
I have my '71 Charger on a rotisserie and was wondering if it would be worth the effort to do a mini tub while it's up there. The car will have a 440 with the '500hp' build, 3.75 gears, and an auto. It will be mainly a cruiser with Friday nights at the local 1/4 mile 'run what ya brung'.
If you did the mini tub which spring relo kit did you use?
How much wider of a tire were you able to fit in?
I am mini tubbing my 64 Savoy so I can install P315 R60-15's. Two issues come up. Exhaust is now custom for the rear section and your diff may need to be shorten to take advantage of the big wheel tubs or a custom back spacing on your rims. I am building a Dana so width is not a biggy for me. With your Charger on the rotissere, now is the time. I cut in a section to the original wheel tub and used the mopar performance kit.
The "look" will be sweet.
64Savoy
[Re: forphorty]
#629706
03/03/10 05:33 PM
03/03/10 05:33 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
Check what wheel and tire combo you want to run, and check for clearance, there is a ton of room built into the tubs already, you just have to play around with backspacing and spring location. I'm running 15x10s without a spring relocation and there is tons of room.
The Blue Goose
My instagram: Bossride
