Hi,
I have my '71 Charger on a rotisserie and was wondering if it would be worth the effort to do a mini tub while it's up there. The car will have a 440 with the '500hp' build, 3.75 gears, and an auto. It will be mainly a cruiser with Friday nights at the local 1/4 mile 'run what ya brung'.
If you did the mini tub which spring relo kit did you use?
How much wider of a tire were you able to fit in?
I am mini tubbing my 64 Savoy so I can install P315 R60-15's. Two issues come up. Exhaust is now custom for the rear section and your diff may need to be shorten to take advantage of the big wheel tubs or a custom back spacing on your rims. I am building a Dana so width is not a biggy for me. With your Charger on the rotissere, now is the time. I cut in a section to the original wheel tub and used the mopar performance kit.
The "look" will be sweet.
64Savoy
