Thermoquad problem; input appreciated #625878
02/27/10 04:40 PM
02/27/10 04:40 PM
Minnesota
peabodyracing Offline OP
Minnesota
I've an 84 1 ton Dodge that's my plow truck. Thermoquad had been leaking most of the winter (lots of use with all the snow this year!) and I finally took it apart to put a kit in it. I can't get the drivers side bowl cavity to quit leaking. It acts like a sunk float; runs rich, gas seeps out through the top gasket at the front of the carb. New floats, new needle/seats, double checked the gaskets on the seat, set the float level three times now. At this point I'm appreciably lower than the stated float position spec. with virtually no improvement. Just using the stock mechanical fuel pump. This was the same leak problem I had before I started, except now I've got the rich condition going too. Double checked the step up rods and they're in position and seem to be working. All indications are it's only rich on the driver's side circuit. I'm feeling pretty stupid about now.
Re: Thermoquad problem; input appreciated [Re: peabodyracing] #625879
02/27/10 04:46 PM
02/27/10 04:46 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
3 Possibilities I know of;
1. Bad needle and seat. I know you replaced them, but I had a similar problem when I rebuilt my TQ. After messing around with it for a few days I finally put the old needles and seats back in and the problem went away.
2. O-ring for the primary jet tower? I think that's what it's called. A pair of bosses from the aluminum top that sets in a wells in the plastic bowl. If you don't put the o-rings in at the bottom of the wells the bowls leak and you get a rich condition.
3. The plastic bowl is warped and/or cracked.
If you're lucky Demonsizzler will see this post and jump in.
No longer taking $h!t from anyone!
Re: Thermoquad problem; input appreciated [Re: peabodyracing] #625880
02/27/10 04:48 PM
02/27/10 04:48 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
no need to feel stupid as the quads can be a pain !
they have a history of cracking the fuel bowls and having leaks , might look closely at the plastic section ???
replace it with a spread bore holley maby ???
good luck
Re: Thermoquad problem; input appreciated [Re: calrobb2000] #625881
02/27/10 04:58 PM
02/27/10 04:58 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
hi
good luck
Coming from a Holley hater; NO WAY!
Re: Thermoquad problem; input appreciated [Re: volaredon] #625882
02/27/10 06:51 PM
02/27/10 06:51 PM
Slantytown
DUFFMAN Offline
DUFFMAN  Offline
Slantytown
IMO You're better off with an Edlebrock than a Holley if you want a good street driver.
Re: Thermoquad problem; input appreciated [Re: DUFFMAN] #625883
02/27/10 06:54 PM
02/27/10 06:54 PM
Re: Thermoquad problem; input appreciated [Re: DUFFMAN] #625884
02/27/10 06:56 PM
02/27/10 06:56 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Bad Boy ....NO Berry-Bumz(or anyone that is not part of the ThermoSquad) on this topic
I will BET it is a sunken float ....a trip to NAPA is in order !
Re: Thermoquad problem; input appreciated [Re: dOc !] #625885
02/27/10 09:30 PM
02/27/10 09:30 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Re-seal jet wells, new o-rings, and new floats if your bowls run dry quickly or gas is puddling in the manifold creating hard re-starts.
If it floods while idling/driving it could be needle/seat or float problem.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Thermoquad problem; input appreciated [Re: MY340] #625886
02/28/10 02:26 PM
02/28/10 02:26 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I always remove the jet wells and reglue them with JB Weld. Get Brass floats from Napa.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Thermoquad problem; input appreciated [Re: dOc !] #625887
02/28/10 04:59 PM
02/28/10 04:59 PM
Slantytown
DUFFMAN Offline
DUFFMAN  Offline
Slantytown
Does running a TQ make me part of the "ThermoSquad"? I have a '72 340 TQ (6139) on my 318.
I was running an Edlebrock 1406 because I was having problems with my tempermental TQ, but I got the TQ straightened out and I'm much happier with the throttle response than I was with the Eddy.
Re: Thermoquad problem; input appreciated [Re: peabodyracing] #625888
02/28/10 07:51 PM
02/28/10 07:51 PM
Minnesota
Minnesota
Guys thanks for the input. I'd already reglued the wells, checked for cracks and put new floats in. Couple of you have mentioned O rings. Can you elaborate on location please? I'm concerned I may have missed those. Thanks again.
Re: Thermoquad problem; input appreciated [Re: peabodyracing] #625889
02/28/10 08:21 PM
02/28/10 08:21 PM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
This web site, 41 pages of info on the TQ.
http://www.carburetor.ca/Tech/Carter/tqguide-Vaanth.html
Re: Thermoquad problem; input appreciated [Re: peabodyracing] #625890
02/28/10 08:34 PM
02/28/10 08:34 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Definitely put the o-rings in. They are the x style rings although I have used standard o-rings also. Thermoquads properly setup are the best carb out there short of all out racing carbs. Great gas mileage when dialed in. Looking down into the phenolic middle section you will notice two wells on each side of the primaries. This is where the o-rings go.
