Re: Thermoquad problem; input appreciated
[Re: peabodyracing]
#625879
02/27/10 04:46 PM
02/27/10 04:46 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
3 Possibilities I know of; 1. Bad needle and seat. I know you replaced them, but I had a similar problem when I rebuilt my TQ. After messing around with it for a few days I finally put the old needles and seats back in and the problem went away. 2. O-ring for the primary jet tower? I think that's what it's called. A pair of bosses from the aluminum top that sets in a wells in the plastic bowl. If you don't put the o-rings in at the bottom of the wells the bowls leak and you get a rich condition. 3. The plastic bowl is warped and/or cracked. If you're lucky Demonsizzler will see this post and jump in.
No longer taking $h!t from anyone!
[Re: peabodyracing]
#625880
02/27/10 04:48 PM
02/27/10 04:48 PM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi no need to feel stupid as the quads can be a pain ! they have a history of cracking the fuel bowls and having leaks , might look closely at the plastic section ??? replace it with a spread bore holley maby ??? good luck
[Re: calrobb2000]
#625881
02/27/10 04:58 PM
02/27/10 04:58 PM
Posts: 2,277 ILLINOIS
volaredon
ILLINOIS
good luck
Coming from a Holley hater; NO WAY!
[Re: DUFFMAN]
#625884
02/27/10 06:56 PM
02/27/10 06:56 PM
Posts: 30,476 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
IMO You're better off with an Edlebrock than a Holley if you want a good street driver.
Bad Boy ....NO Berry-Bumz(or anyone that is not part of the ThermoSquad) on this topic
I will BET it is a sunken float ....a trip to NAPA is in order !
[Re: dOc !]
#625885
02/27/10 09:30 PM
02/27/10 09:30 PM
Posts: 5,270 Missouri
MY340
Missouri
Re-seal jet wells, new o-rings, and new floats if your bowls run dry quickly or gas is puddling in the manifold creating hard re-starts.
If it floods while idling/driving it could be needle/seat or float problem.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#625886
02/28/10 02:26 PM
02/28/10 02:26 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I always remove the jet wells and reglue them with JB Weld. Get Brass floats from Napa.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: peabodyracing]
#625890
02/28/10 08:34 PM
02/28/10 08:34 PM
Posts: 1,061 New Mexico
dmerc
New Mexico
Definitely put the o-rings in. They are the x style rings although I have used standard o-rings also. Thermoquads properly setup are the best carb out there short of all out racing carbs. Great gas mileage when dialed in. Looking down into the phenolic middle section you will notice two wells on each side of the primaries. This is where the o-rings go.
