64 dodge polara #625541
02/27/10 02:01 AM
02/27/10 02:01 AM
strum, WI
demonbeekeepr Offline OP
strum, WI
looking for some advice got the old style 8 3/4 axles in my car looking to up date which is the best and cheapest route to go? Also want strength want to stay with the an 8 3/4 .
Re: 64 dodge polara [Re: demonbeekeepr] #625542
02/27/10 02:19 AM
02/27/10 02:19 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
id go with 65-70 b-body rear.
Re: 64 dodge polara [Re: moparsquid] #625543
02/27/10 02:23 AM
02/27/10 02:23 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
And I believe the 66-67s are the shortest...
Re: 64 dodge polara [Re: demonbeekeepr] #625544
02/27/10 02:37 AM
02/27/10 02:37 AM
strum, WI
strum, WI
can i just replace the axles with the newer style has the cutter pin stlye in it now.
Re: 64 dodge polara [Re: demonbeekeepr] #625545
02/27/10 02:53 AM
02/27/10 02:53 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
no, different lengths.
Re: 64 dodge polara [Re: RemCharger] #625546
02/27/10 08:09 AM
02/27/10 08:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dr Diff i believe has a kit to run new style axles in them.Probally cheaper and easier to jut get a 65 to 70 B body rear.The 65 66 for sure are the narrowest.I believe 67 is also.Rocky
Chrysler Firepower
Re: 64 dodge polara [Re: demonbeekeepr] #625547
02/28/10 12:16 AM
02/28/10 12:16 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Talk to Dr. Diff. I think he has axles that you can cut to length. The bolt pattern on the axle flange is the same as the newer style bearing retainers. It seems to me you might have to grind a bit of the flange for the newer brake backing plates to slide over. Hardest part of the whole deal will be getting the old axles out.
Sheldon
Re: 64 dodge polara [Re: RUNCHARGER] #625548
02/28/10 02:52 AM
02/28/10 02:52 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I went with a 66/67 B rear.
It was the cheapest option for me anyway.
I think I paid 150 for the housing and axles.
Re: 64 dodge polara [Re: dave571] #625549
02/28/10 08:57 AM
02/28/10 08:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
One big problem is the taper set with shims.Newer axles set with the screw adjuster on the right axle.I know Dr Diff has a conversion.My 65 azle is under the kids 62 300.When we finally scrap the 66 Charger Ill save the rear from it also.Rocky
Chrysler Firepower
Re: 64 dodge polara [Re: therocks] #625550
02/28/10 10:08 AM
02/28/10 10:08 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I've got one from a 66 Charger in my 64 Polara.
A little wider than the orig. but bolted right in. Spring perches are in the right location.
There are others that will work also,I just happened to have a friend with a Charger.
Re: 64 dodge polara [Re: pushbutton] #625551
02/28/10 02:42 PM
02/28/10 02:42 PM
dave571 Offline
dave571  Offline
It should have been narrower than the original. I know mine was.
There are reference charts that show them being the same width, but when I measured my original, it was larger than chart said, and so was the one in my 64 parts car.
Re: 64 dodge polara [Re: dave571] #625552
02/28/10 02:48 PM
02/28/10 02:48 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have a 68 Gtx rear under mine and it fits perfect....
Re: 64 dodge polara [Re: QuickBpBp] #625553
02/28/10 07:35 PM
02/28/10 07:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Got a 65 Ply rear in my 63 and it fit perfect. It seemed to be the same size as the stock rear that was in it. Ron
Re: 64 dodge polara [Re: 383man] #625554
02/28/10 07:43 PM
02/28/10 07:43 PM
Well, I have an 8 3/4 rear end from a 66 Charger under my 64 Polara. Reason? I already had a 66 Charger parts car, so it was free.
I can't tell you if it is wider or narrower than the original, but, other than I think I had to change out one of the emergency brake cables, it bolted right in.
Re: 64 dodge polara [Re: dave571] #625555
03/02/10 02:51 AM
03/02/10 02:51 AM
dave571 Offline
dave571  Offline
Let me clarify, it wasn't much narrower. Like 3/4 inch or something.
It was a straight bolt in. BUT definately narrower.
First I tried to use the axles only, and there wasn't enough contact area on the splines, cause the axles were a little shorter. Then went with the housing.
I'm sure we ALL agree that getting rid of the hassel of tapered axles, was a HUGE relief
Re: 64 dodge polara #625556
03/02/10 10:31 AM
03/02/10 10:31 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Do you remember which cable you changed?
My drivers side doesn't release like it should,
thought I changed it,but maybe not.Do you remember what the cable you used came out of?
Thanks.
Re: 64 dodge polara [Re: pushbutton] #625557
03/02/10 11:06 AM
03/02/10 11:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have done the 64 to later axle conversion. The problem is that the housing is not machined to accept inner axle seals. You must run the green style bearing which does not require the inner seal. These bearings don't require the end play adjusters either. All you need are the correct length axles and green bearings. It's not a big deal.
Doug
