Re: 64 dodge polara
[Re: RemCharger]
#625546
02/27/10 08:09 AM
02/27/10 08:09 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Dr Diff i believe has a kit to run new style axles in them.Probally cheaper and easier to jut get a 65 to 70 B body rear.The 65 66 for sure are the narrowest.I believe 67 is also.Rocky
Chrysler Firepower
Re: 64 dodge polara
[Re: dave571]
#625549
02/28/10 08:57 AM
02/28/10 08:57 AM
therocks
Niles , Ohio
One big problem is the taper set with shims.Newer axles set with the screw adjuster on the right axle.I know Dr Diff has a conversion.My 65 azle is under the kids 62 300.When we finally scrap the 66 Charger Ill save the rear from it also.Rocky
Chrysler Firepower
Re: 64 dodge polara
[Re: therocks]
#625550
02/28/10 10:08 AM
02/28/10 10:08 AM
Posts: 1,565 tennessee
pushbutton
tennessee
I've got one from a 66 Charger in my 64 Polara. A little wider than the orig. but bolted right in. Spring perches are in the right location. There are others that will work also,I just happened to have a friend with a Charger.
Re: 64 dodge polara
[Re: 383man]
#625554
02/28/10 07:43 PM
02/28/10 07:43 PM
Well, I have an 8 3/4 rear end from a 66 Charger under my 64 Polara. Reason? I already had a 66 Charger parts car, so it was free.
I can't tell you if it is wider or narrower than the original, but, other than I think I had to change out one of the emergency brake cables, it bolted right in.
Re: 64 dodge polara
[Re: dave571]
#625555
03/02/10 02:51 AM
03/02/10 02:51 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
It should have been narrower than the original. I know mine was.
There are reference charts that show them being the same width, but when I measured my original, it was larger than chart said, and so was the one in my 64 parts car.
Let me clarify, it wasn't much narrower. Like 3/4 inch or something. It was a straight bolt in. BUT definately narrower.
First I tried to use the axles only, and there wasn't enough contact area on the splines, cause the axles were a little shorter. Then went with the housing.
I'm sure we ALL agree that getting rid of the hassel of tapered axles, was a HUGE relief
