Battery relocation wire question #624198
02/25/10 05:15 PM
02/25/10 05:15 PM
Ohio
fiddlestix Offline OP
Ohio
I am looking on E-bay and found 2 different 1/0 wires for a battery relocation. Which one of these would be better and why? Thanks for the help.
BRAND NEW 25' OF EXCELENE 1/0 WELDING CABLE IN RED VERY HIGH FLEXIBILITY CABLE THAT IS MADE IN THE USA, +105C-50C 600V CONDUCTOR STRANDING IS 19X54/30 = STRANDS OF BARE COPPER. NOMINAL O.D IS 0.55 AND NOMINAL WALL THICKNESS IS 0.08
or
Color: Silver
Competition series
Best series from the best brand for wires
These are the thickest and best wires on the market. These can handle any amplifier.
Patented technology only from Monster allows greater current transfer
Patented construction makes this cable very flexible for ease of installation
Oxygen free
Designed for show car performance
Extreme thickness
Ultra-Pure copper conduction
Magnetic Flex Tube technology (Only from monster)
High current power handling
Protective jacket
25 foot
this is Monster cable usually used for auto amplifiers.
Re: Battery relocation wire question [Re: fiddlestix] #624199
02/25/10 05:31 PM
02/25/10 05:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive heard not to use welding cable.Look at it. The strands are real thin.Most experts will say no.Just get regular battery cable.I wouldnt trust speaker cable.I know guys will chime in and say they run welding cable.I dont I just get 25 feet of battery canle in 1 gauge..Rocky
Chrysler Firepower
Re: Battery relocation wire question [Re: fiddlestix] #624200
02/25/10 06:13 PM
02/25/10 06:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
or
Color: Silver
Competition series
Oxygen free
Extreme thickness
Protective jacket
25 foot
Monster cable is really just over priced for the audio guys. Its not speaker wire, its designed to power a large audio amplifier. Welding cable strands are very fine, similar to a DLO cable which is designed for Diesel Locomotive connections. Welding cable would work great in that application. It has a thick flexable jacket, handles very high ampacities, and is easy to get. JUst be very concious of your terminations not to leave exposed copper and use a good crimp connection on the wire, no mechanical stuff
Re: Battery relocation wire question [Re: therocks] #624201
02/25/10 06:18 PM
02/25/10 06:18 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
OK, I know people have opinions on this subject, that being said copper wire transfers current on the outside of said strand, meaning a cable with more strands has less impedence than a cable with fewer strands, welding cable has a softer jacket to it to allow a welder to move around, thats all the other cables have a stiffer jacket to take abrasions and abuse, one not being better than the other in a race car enviroment, back to your normal daily opinions. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Battery relocation wire question [Re: fiddlestix] #624202
02/25/10 06:27 PM
02/25/10 06:27 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
you'll also need a ground cable to terminate close to the starter on the engine block and a ground lug off that for accessories. I see a lot of guys use the body of the car for ground IE ground from battery to the body then pick up grounds off the body. Not the best plan IMO.
Re: Battery relocation wire question [Re: Rodney] #624203
02/25/10 06:34 PM
02/25/10 06:34 PM
Ohio
Ohio
Thanks for your oppinions. If I understand correctly more strands are better? I have found welding cable and Monster cable both 1/0 for exacctly the same price $60/25ft. Which would you think is better for this application?
Re: Battery relocation wire question [Re: fiddlestix] #624204
02/25/10 06:40 PM
02/25/10 06:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just get the kit from painless. you don't really need 1 guage. #2 will do fine. the kit comes with all the ends you will need.
Re: Battery relocation wire question [Re: fiddlestix] #624205
02/25/10 06:42 PM
02/25/10 06:42 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Correct, more strands, better for our application. I dont think one would be any better than the other. Monster cable used to make a good product, and it may have a pvc jacket of sorts that will createa little better barrier from the elements it you are running it outside the car. The other side of that is the rubber jacket on the welding cable will be thicker. I dont think you will have issues either way, but I personally would pick welding cable, but Im an electrician so my opinion my be swayed because of that.
Also check with your local electrical supply house... ie CED or Crescent or Wesco and ask them to quote you welding cable, or DLO cable.
Re: Battery relocation wire question [Re: joshking440] #624206
02/25/10 06:50 PM
02/25/10 06:50 PM
Woodstock , Georgia
Woodstock , Georgia
Nothing against painless wiring , but most of kits are only 15ft. like Josh said check your local electrical supply houses, they also have the correct stlye lugs to use also. and Iagree with Rodney, we also run same size neg cable back, chassis is not the best ground. John
Re: Battery relocation wire question [Re: joshking440] #624207
02/25/10 06:52 PM
02/25/10 06:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've had my Welding Cable....I mean Battery Cable on my car for over 20 years.
Never an issue and personally I like it.
Re: Battery relocation wire question [Re: roadhazard] #624208
02/25/10 06:58 PM
02/25/10 06:58 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Call terminal supply company. I just bought 25 ft roll of 0/1 and it was about 65$, and they tossed in 4 ft of 0/1 ground for free. The top post battery ends are about 5$ each.
You get what you pay for. Originally my dad bought a Taylor kit. The brackets were good, but the insulation was cheap. It did not with stand the heat when soldering the ends on. The terminal supply wire did a great job with standing the heat (and its actually for automotive use).
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Battery relocation wire question [Re: wldtm] #624209
02/25/10 07:01 PM
02/25/10 07:01 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Just my opinion, but a good compression crimped connection is better than a soldered one in high ampacity situations like this
Re: Battery relocation wire question [Re: joshking440] #624210
02/25/10 07:09 PM
02/25/10 07:09 PM
Ohio
Ohio
Do most people run their ground all the way to the engine block or just the frame? Also, I recall seeing a post showing a wiring diagram for mounting the solenoid and shutoff switch in the trunk. Does anyone know where that link is? Thanks
Re: Battery relocation wire question [Re: fiddlestix] #624211
02/25/10 07:17 PM
02/25/10 07:17 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Not sure of your ignition system, but most of them prefer ground going back to the battery and not the frame, so if you have to run ground to the front of the car anway, you might as well just run a large one and hit a distribution block and take good grounds to all your equipment
Re: Battery relocation wire question [Re: joshking440] #624212
02/25/10 07:39 PM
02/25/10 07:39 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
I would have preferred them crimp the connection, because i think they can make it look cleaner. I agree a properly crimped connection is as good as a well done soldering job.
On mine, the power feed runs directly to the bat stud of the starter. The ground goes to the frame (through the on/off kill switch). At the engine there is a ground from the head to the frame. I will also have one a body to chassis ground, (mainly for lighting circuits).
To make it cleaner they also sell 3/4" id adhesive lined heat shrink in red for positive post. Black for negative. Makes it look really nice.
THe trick I found on melting the solder without char broiling the insulation is heat only on the terminal end, and use the heat to pull the solder in.
Justin
www.terminalsupplyco.com
Re: Battery relocation wire question [Re: wldtm] #624213
02/25/10 08:36 PM
02/25/10 08:36 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Welder lead for the positive on mine from the master cuttoff to the starter,along with ground cable from battery to chassis and then from the chassis to the block up front.Using heavy copper wire from alt all the way to the battery in the trunk .No issues and starts and charges every time ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Battery relocation wire question [Re: The Shocker] #624214
02/25/10 08:43 PM
02/25/10 08:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: Battery relocation wire question [Re: Mopar_racer_99] #624215
02/25/10 08:51 PM
02/25/10 08:51 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Not exactly, when you mentioned "impedance", you are referring to AC current, cars are DC. AC does like the surface of a conductor, hence the need for multi strands in AC situations, however I would use the welding cable for a number of other reasons already mentioned, and leave the monster cable for the smug audio guys and the I was going to say ricers, but why pick on them?.
When I crimp heavy cable at work, I use a greasy specificly design wire compound that helps prevent corrosion and oxidation, then i tape or heat shrink that to keep out moisture, your number one long term problem in keeping a connection solid.
Re: Battery relocation wire question [Re: Stanton] #624216
02/25/10 08:54 PM
02/25/10 08:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Might want to check out a marine supply for the cable. If your running the cable out side of the car. Welding cable will draw moisture, marine cable will not. I run both cables from the battery switch at the back to the engine, also grounding at the back frame.
Re: Battery relocation wire question [Re: rowin4] #624217
03/23/10 12:19 AM
03/23/10 12:19 AM
Beeton Ontario. Canada
BigSugar Offline
BigSugar  Offline
Did You run a 1/0 Ground back too the battery and ground the 1/0 to the rear frame as well ?
Could you not use a smaller gauge Ground at the rear frame if your running a full ground battery too block anyway ?
Ron
