Re: Turn signals not working
[Re: DAMOPARS]
#61939
05/23/08 12:23 PM
05/23/08 12:23 PM
Posts: 8,677 Buford, GA
I_bleed_MOPAR
Buford, GA
Do the indicators in the cluster light up? Do the front and rear lights come on but don't blink? When I had my '70 Dart the turn signals and brake lights were acting weird. IIRC, the turn signal would only blink on one side and the brake lights only worked on one side (been a while). My dad told me what the problem was- the turn signal switch. ![](/ubbthreads/images/graemlins/thumbs.gif) Anyway, a quick check at O'Reillys shows a switch available- other places may have them. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: stumpy]
#61942
05/23/08 01:18 PM
05/23/08 01:18 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
The wiring for the emergency flashers and turn signals is the same wires. If you got flashers and no turns then you most likely have and bad switch. I know you said you replaced the flashers but try swapping them and see what happens.
Good advice, I had a flasher that was playing hell on my wiring. Replaced it with a second "new" one and it worked. ![](/ubbthreads/images/graemlins/iagree.gif)
