Turn signals not working #61937
05/23/08 09:26 AM
05/23/08 09:26 AM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
70 dart my turn signals are not working,
I checked all the bulbs and fuses all are good,
flashers work and replaced both flashers. The ground is good but will try another spot.
What next?
If it is the switch where can I get one?
Dealer?
Re: Turn signals not working [Re: DAMOPARS] #61938
05/23/08 11:44 AM
05/23/08 11:44 AM
michigan
black64 Offline
black64  Offline
michigan
Make sure your ground strap from the engine to the body is good.
Re: Turn signals not working [Re: DAMOPARS] #61939
05/23/08 12:23 PM
05/23/08 12:23 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Do the indicators in the cluster light up? Do the front and rear lights come on but don't blink? When I had my '70 Dart the turn signals and brake lights were acting weird. IIRC, the turn signal would only blink on one side and the brake lights only worked on one side (been a while). My dad told me what the problem was- the turn signal switch. Anyway, a quick check at O'Reillys shows a switch available- other places may have them.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Turn signals not working [Re: I_bleed_MOPAR] #61940
05/23/08 12:45 PM
05/23/08 12:45 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
No lights at all at the bulbs or the dash,
But the flasher lights work and on the dash also.
Do these run through the bulk head connector? Which wires are they?
Re: Turn signals not working [Re: DAMOPARS] #61941
05/23/08 01:14 PM
05/23/08 01:14 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
The wiring for the emergency flashers and turn signals is the same wires. If you got flashers and no turns then you most likely have and bad switch. I know you said you replaced the flashers but try swapping them and see what happens.
Re: Turn signals not working [Re: stumpy] #61942
05/23/08 01:18 PM
05/23/08 01:18 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Good advice, I had a flasher that was playing hell on my wiring. Replaced it with a second "new" one and it worked.
Re: Turn signals not working [Re: stumpy] #61943
05/23/08 01:19 PM
05/23/08 01:19 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
I did and the flashers only work.
Going to look for a switch.
