Re: 426 Hemi with Auto transmission
[Re: HPMike]
#616661
02/20/10 07:13 PM
02/20/10 07:13 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
FYI These are the flexplate bolts you need to not have any issues with interference when using a standard 727 converter with a hemi(or any 8 bolt flange) crankshaft. Note the very thin head. They fit fine and won't hit the back of the converter, but they are too long and you need to take about 1/4" off them or they will hit the rear main seal retainer. No big deal- I just use a cutoff wheel and radius the cut edge. You also need to buy two pkgs as they only come in a pack of 6 . ARP may make a proper bolt- I just got used to these and they aren't ridiculously priced. http://www.summitracing.com/parts/MRG-914/?rtype=10MB
[Re: HPMike]
#616662
02/21/10 05:30 PM
02/21/10 05:30 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
But additionally, and this is VERY important, the back cover is dished to accomodate the larger bolts(and diameter) of the 8 bolt crank.
