426 Hemi with Auto transmission #616651
02/18/10 01:47 AM
02/18/10 01:47 AM
California
1970mopar Offline OP
California
Looking for recommendations on a direct replacement, OEM style, OEM stall speed, torque converter for a %100 OE 1970' 426 Hemi w/ 727 Hemi Transmission.
thanks in advance
Re: 426 Hemi with Auto transmission [Re: 1970mopar] #616652
02/18/10 08:18 AM
02/18/10 08:18 AM
florida
P
PJM Offline
PJM  Offline
P
florida
I would call JW, TCI,B&M and ask their tech guys what they recommend. I know JW has built me specific stall speeds for my applications in the past with great results.
Re: 426 Hemi with Auto transmission [Re: PJM] #616653
02/18/10 09:00 AM
02/18/10 09:00 AM
Washington
69440 Offline
69440  Offline
Washington
John Winters built mine and I couldn't be happier.
Re: 426 Hemi with Auto transmission [Re: 69440] #616654
02/18/10 02:27 PM
02/18/10 02:27 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
For a low buck solution we use stock 340 replacement converters and drill the lugs for hemi sized bolts.
Mike
Re: 426 Hemi with Auto transmission [Re: rocketresto] #616655
02/18/10 06:01 PM
02/18/10 06:01 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I used the Hemi converter from Turbo Action for my stock resto 68 Hemi Road Runner and I am very happy with it.
Re: 426 Hemi with Auto transmission [Re: 68jim] #616656
02/18/10 06:39 PM
02/18/10 06:39 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
I also go the low dollar route. Using the '68 383HP torque converter is the same unit as the street hemi's, except for the bolt size of course. This info was in one of the older Direct Connection manuals and there was a very good section telling about which converters the factory had used. Either way these 383 units(called the Falcon?) work out rather well for a stall around 2850 IIRC Good Luck!
Re: 426 Hemi with Auto transmission [Re: QuickSilver] #616657
02/20/10 04:21 PM
02/20/10 04:21 PM
California
California
From what I gather none of the converter companies actually make an OE replacement you can purchase off the shelf. -
I'll make a few inquiries from the info posted above. Thanks again
Re: 426 Hemi with Auto transmission [Re: 1970mopar] #616658
02/20/10 06:14 PM
02/20/10 06:14 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Pete,
Talk to John Cope, he'll build you one to the exact specs your after
Re: 426 Hemi with Auto transmission [Re: 1970mopar] #616659
02/20/10 06:18 PM
02/20/10 06:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
scratch that , it doesn't have the correct lugs for hemi bolts
Re: 426 Hemi with Auto transmission [Re: JohnRR] #616660
02/20/10 07:08 PM
02/20/10 07:08 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
A "true" street hemi torque converter has quite a few differences than a run of the mill wide ring gear TF8 converter. They are high stall and utilize the larger mounting bolts. But additionally, and this is VERY important, the back cover is dished to accomodate the larger bolts(and diameter) of the 8 bolt crank. You can use a "conventional" 727 high stall converter core, but you will need to use wafer thin flexplate bolts as to not interfere(contact) the converter back cover. Many converter companies like Dacco have referred to a wide ring gear, neutral balance, high stall converter as a "hemi" converter in the generic sense, but unless they are using an actual street hemi core it isn't a true hemi converter.
I have a few originals at the shop. I could possibly photograph if someone needed to see it.
MB
Re: 426 Hemi with Auto transmission [Re: HPMike] #616661
02/20/10 07:13 PM
02/20/10 07:13 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
FYI
These are the flexplate bolts you need to not have any issues with interference when using a standard 727 converter with a hemi(or any 8 bolt flange) crankshaft. Note the very thin head. They fit fine and won't hit the back of the converter, but they are too long and you need to take about 1/4" off them or they will hit the rear main seal retainer. No big deal- I just use a cutoff wheel and radius the cut edge. You also need to buy two pkgs as they only come in a pack of 6 . ARP may make a proper bolt- I just got used to these and they aren't ridiculously priced.
http://www.summitracing.com/parts/MRG-914/?rtype=10
MB
Re: 426 Hemi with Auto transmission [Re: HPMike] #616662
02/21/10 05:30 PM
02/21/10 05:30 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Re: 426 Hemi with Auto transmission [Re: 1970mopar] #616663
02/23/10 02:35 PM
02/23/10 02:35 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Have you looked for an original? They're still around. I bought a spare a few years ago and have seen some on eBay. Not sure if I want to sell mine just yet but believe me when I say start looking(calling) around.
Fred
Re: 426 Hemi with Auto transmission [Re: 52savoy] #616664
02/23/10 06:46 PM
02/23/10 06:46 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Here is an original that came with my cuda, was going to use it but, did not use as I went with a 10" new race converter with 2700 stall per Bob K's recommendation.
